OK, no one mentioned lubercants
You can use dishwashing liquid and a little water for plastics.
No one has mentioned Pilot-point bits. Great bits for drilling into sheet metal and plastics. They also make round holes rather than triangular shaped in sheet metal.
Also, no one has mentioned transfer punches. Say for example you need to drill a hole for a CPC connector. This needs a large center hole and 4 evenly spaced holes in a square pattern. You drill the large hole. Then place the connector and use a "transfer punch" to align the first hole. Then repunch with a center punch.
Now insert the connector again ans tighten using one of the screws. Now transfer the other three holes. Remove the connector. Repunch and drill.
I once drilled the top of a case for feet. Fix. I just countersunk 4 screws into the holes.
I second the method of a template done in a CAD program.
