William At MyBlueRoom
Here's the layout (sorry it's lores here, I'll post a full size on my site asap)
I want to remove the crystal on the 18F2525 *you can calibrate it with the DS1306 32KHz
I even considered using a 7.3728MHz oscillator and the /4 to drive the MAX3110E at 1.8MHz but I'd rather use less crystals than more... SO What shall I do with the 2 I/O pins RA6 & RA7?
This Firefly can work standalone as a PLC or a good way to test your C skills as the 18F is better suited for C than a 16F PIC.
The PCB will be another 107x57mm for fitting in a Hammond enclosure.
