Hello,
I just purchased a “72 LED multi-purpose work light” from ASDA supermarket.
It says it was produced for “Status International (UK) Ltd” (£7)
This runs on four-in-series AA batteries (Alkaline batteries have on_load terminal voltage of 1.1 to 1.3V)
72 LED lamp schematic: (also below in PDF)
https://i41.tinypic.com/17zo6r.jpg
The LEDs are all basically in parallel as you can see. It’s three lots of 24 LEDs in parallel. These 24 paralleled LEDs have no added resistances to equalise the currents in them.
Does this mean that the LEDs must have resistance built in to their silicon?
I supplied one of these Work Lights with 4.4V, and found that the total current drawn was 447mA.
The voltages across each of the 10R resistors was 1.453V, 1.471V & 1.465V. As you can see, this means about 210mW being dissipated in each of these 0805 resistors. –That is above the absolute maximum allowed for an 0805 resistor. A 2010 resistor would have cost little more than 0805. Why did they not just use 2010 resistors instead of 0805s?
(remember that AA cells can sometimes be 1.3V,and that would have meant even more disspation in these 10R resistors….in fact , in a separate test, i supplied the product with 5V, and found the dissipation in each of these 10R’s was 412mW)
The LED forward voltage was 2.93V
With equal sharing, each LED will only have 6.2mA in it. Presumably these LEDs are 30mA rated LEDs (they look like it). So is this why they are OK with parallel operation?…i.e., because they are being operated at the lower end of the I/V curve where the dnamic resistance is much higher?
I note that regarding the three 10R resistors, one has the value text pointing up….but the other two 10R’s are “upside down”, and the value lettering cannot be seen. I suspect that this is a kind of “factory coding” to indicate that these units have been through production soak testing.?
I suspect that 0805 resistors have been used, because if any of the products have widely variant LED forward voltages, then there is more chance of the 0805 resistors burning out during soak test….and the staff can see that a resistor is burnt out , and simply bin the product, rather than ship it?
How are they getting away with so many LEDs in parallel and so badly under-rated resistors?
