TheJay
This is interesting, I think that the PSU element is glued though, so I don't think it would be feasible to replace the entire length like this?
That's what I mean, I didn't want to make a mess cutting it open. Surely that's going to look messy? Also, what kind of glue to you use to stick it back together? It would need to be very resistant to heat.
I order a LOT from Aliexpress, they are fairly decent on speed these days - 2 to 3 weeks is probably all.Okay, so it might take two months to arrive but it was £2.74.
No, you don't need to try and duplicate it - it's simply had too much solder applied.Sounds good to me!
Out of interest, how come the solder on the three wires where they go through the circuit board is dome shaped? It's not like that elsewhere. I've never seen solder like that before, do I need to replicate and if so, how is that done?
It looks as though there is some kind of ferrule crimped on to the end of the wires, and whoever soldered the wire/ferrule onto the board used a BIG BLOB of solder.how come the solder on the three wires where they go through the circuit board is dome shaped?
Good.It's not like that elsewhere. I've never seen solder like that before,
No, big blobs like that are considered to be bad technique and would fail any critical QA inspection.do I need to replicate
Where the soldering QA mantra is often:Not in China!![]()
Is it soldering you're talking about?Where the soldering QA mantra is often:
" The bigger the blob, the better the job"
