0.000000 A or 0.000010 A?One more requirement. It has to use no power in the default/off state.
ak
ak
There exist toggle relays which basically have two coils to change over from one state to the other. I have seen them in electricity prepayment meters. These coils were low voltage coils. Have a loo on eBay.
Not really. I understand how relays work, and that with them, off is really off. My question is whether or not a few microamps of CMOS static current is acceptable. In some applications, even that small current is not allowed. If your's can handle it, that opens up a large range of possibilities -A bit of a moot point.
Probably so, because the output changes state in one direction while the input remains in one state, then has to change in the other direction when the input returns to that same state. Looks like a race condition.I was looking for the simplest solution, hopefully with just 2 relays. So far, it looks like that's an impossibility.
I actually already ordered the first one as I think it does what I want. I guess I'll find out when it gets here and I try it![]()
If you are sure that you want a solution which only uses relays, look here:
Step 2 puts the two relay coils in series on a 12V circuit. Is ~7V enough to energize an automotive relay?
So, exactly what I and I would think many others need is already 'no longer available'. Brilliant. Not exactly how I imagine 'supply and demand' should work.
Thanks for the info though.
That's a good point. There are 2 things to consider. Firstly, they are only required to HOLD themselves on at this reduced voltage and most relays will hold at half their rated voltage. They actually get the full 12v when being energised. Secondly, they could be any type of relay not just standard automotive relays (which tend to not be DPDT anyway). One could even use 6v relays which would cope with momentary application of 12v when being energised. Or you could add a couple of resistors to limit energising voltage.
So several ways to avoid the problem.
That circuit above is extremely clever...
