lcd menu
Hi, thanks for all the help again. Have just tried your last suggestion and now get:
"waiting"
press menu
">option 1"
"option 2"
press down
"option 3"
"option 3"
press down
"|:;;\\\ 3"
"op:\|| 3"
press up
"option 1"
"option 1"
sure here it is:
#define MENU   2
#define UP  3
#define DOWN  4
// LCD connections definitions
sbit LCD_RS at RA0_bit;
sbit LCD_EN at RA1_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISA0_bit;
sbit LCD_EN_Direction at TRISA1_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD connections definitions
 unsigned char MainMenuLIST[3][16] = {
{"Option 1"},
{"Option 2"},
{"Option 3"}
unsigned char WaitForInput(void){
        unsigned char done = 0; //DONE Var will determine if done and hold key
        while(!done){                                  //while done == 0
    if (Button(&PORTA, MENU, 1, 0))
          done = MENU;
    if (Button(&PORTA, UP, 1, 0))
          done = UP;
    if (Button(&PORTA, DOWN, 1, 0))
          done = DOWN;
        return done;                                  //Return our done/key var
void MainMenu(void){
unsigned char POS = 0; 	//Used for cursor ONLY!
unsigned char x;
unsigned char ITEM=0;
unsigned char PAGE=0;
Lcd_Cmd(_LCD_CLEAR);
while(!done){
	for(x=0;x<2;x++){
		if(x == POS)
   Lcd_Out((x+1),1,">");
		else
   Lcd_Out((x+1),1," ");
        Lcd_Out((x+1),2,MainMenuLIST[(x+PAGE)]);
	switch(WaitForInput()){
		case UP:
			if(POS>0){
				POS--;
				ITEM--;
			} else {
        if(PAGE != 0) PAGE--;
			break;
		case DOWN:
			if(POS<1){
				POS++;
				ITEM++;
			} else {
        PAGE++;
			break;
		case MENU:
			done = 0xFF;
			break;
	// ITEM contains what item is selected
	// POS isnt used incase larger then 2 menu...
  ITEM+=PAGE;
	switch(ITEM){
		case 0:
                Delay_ms(2000);
			break;
		case 1:
                Delay_ms(2000);
			break;
	//Bring our title back.. cuz we are done with the menu...
void main() {
  unsigned char x;
  CMCON  |= 7;                       // Disable Comparators
  TRISA = (0x0F<<2);                 // RA5,RA4,RA3,RA2 are set to input
  Lcd_Init();                                    // Initialize LCD
  Lcd_Cmd(_LCD_CLEAR);                           // Clear LCD
  Lcd_Cmd(_LCD_CURSOR_OFF);                      // Turn cursor off
  Lcd_Out(1, 3, "Waiting");
      do {
                case MENU:
                Delay_ms(100);
                MainMenu();
                break;
} while (1);
hey try this lol sorry:
#define MENU   2
#define UP  3
#define DOWN  4
{"Option 1"},
{"Option 2"},
{"Option 3"}
          done = MENU;
          done = UP;
          done = DOWN;
unsigned char x;
while(!done){
	for(x=0;x<2;x++){
		if(x == POS)
		else
		case UP:
			if(POS>0){
				POS--;
				ITEM--;
			} else {
			break;
		case DOWN:
			if(POS<1){
				POS++;
				ITEM++;
			} else {
[B]        PAGE=1;[/B]
			break;
		case MENU:
			done = 0xFF;
			break;
  ITEM+=PAGE;
	switch(ITEM){
		case 0:
                Delay_ms(2000);
			break;
		case 1:
                Delay_ms(2000);
			break;
void main() {
  unsigned char x;
      do {
                case MENU:
                Delay_ms(100);
                MainMenu();
                break;
} while (1);
Almost there :)
now it displays:
"Waiting"
press menu
">Option 1"
"Option 2"
press down
"Option 2"
">Option 3"
press UP
">Option 1"
"Option 2"
so Option 2 can never be selected
try:
#define MENU   2
#define UP  3
#define DOWN  4
{"Option 1"},
{"Option 2"},
{"Option 3"}
          done = MENU;
          done = UP;
          done = DOWN;
unsigned char x;
while(!done){
	for(x=0;x<2;x++){
		if(x == POS)
		else
        Lcd_Out((x+1),2,MainMenuLIST[x]);
		case UP:
			if(POS>0){
				POS--;
				ITEM--;
			} else {
			break;
		case DOWN:
			if(POS<2){
				POS++;
				ITEM++;
			} else {
        if(PAGE<1){
          ITEM--;
          POS--;
          PAGE=1;
			break;
		case MENU:
			done = 0xFF;
			break;
	switch(ITEM){
		case 0:
                Lcd_Out(1, 3, "temp   ");
                Delay_ms(2000);
			break;
		case 1:
                Lcd_Out(1, 3, "Time");
                Delay_ms(2000);
			break;
void main() {
  unsigned char x;
      do {
		case MENU:
		Delay_ms(100);
		MainMenu();
		break;
} while (1);
The above code should do it. I even changed my code to mimic it in my menu:
;    Filename:                     				                              *
;    Date:        *
;    File Version: 001                                                        *
;    Author:   Jason Lopez                                                    *
;    Company:  AtomSoft                                                       *
#include <p18F4620.h>
#include <delays.h>
#include <string.h>
#include "lcd.h"
#include "keys.h"
#pragma config WDT = OFF, LVP = OFF, OSC = HS, XINST = OFF
unsigned rom char MainMenuLIST[2][16] = {
{"Change View "},
{"Change Speed"}
unsigned rom char SpeedMenuLIST[3][16] = {
{"500 mS   "},
{"1 Second "},
{"2 Seconds"}
unsigned rom char Company[16]="  AtomSoftTech  ";
unsigned rom char SpeedLIST[3][16] = {
{"Update: 500 mS"},
{"Update:  1 sec"},
{"Update:  2 sec"}
Prototypes
void main(void);
unsigned char DECtoBCD(unsigned char DEC);
unsigned char DECtoASCII(unsigned char DEC,char part);
Variables and Defines
    #define ADCPin TRISAbits.TRISA0 // RA0/AN0 TRIS (DATA DIRECTION REGISTER)
    unsigned int oldresult; //Old Result Variable
    unsigned int result;    //Result Variable
    unsigned int DegC;      //Result in Celsius
    unsigned int DegF;      //Result in Fahrenheit
    unsigned int DelayTime; //Delay Length
    unsigned char MyView;
    unsigned char lcdtmp[10];
    unsigned char avg[10];
    unsigned char CompSpeed;
Main
void main(void){
    unsigned char tmp;
    unsigned long tmp1;
    TRISD = 0x00;
	KeyDIR = 0x0F;
    ADCPin = 1;                     //AN0 = Input
    ADCON0 = 0x00;                  //BIT 7:6 Always 00, BIT 5:2 is 0000 for Channel 0 (AN0),
                                    //BIT 1:0 is 00 (A/D Idle and Module is off) until we are done setting up
    ADCON1 = 0x0E;                  //BIT 7:6 Always 00, BIT 5 is 0 for VSS, BIT 4 is 0 for VDD
                                    //BIT 3:0 is 1110 for all digital expect AN0. We need it analog so we can convert it.
    ADCON2 = 0b10001101;            //BIT 7 is 0 for Left Justified, BIT 6 Always 0, BIT 5:3 001 for 2 TAD (A/D Acquisition Time)
                                    //BIT 2:0 is 100 for FOSC/4 for A/D Conversion Clock
    ADCON0bits.ADON = 1;            //Turn on the A/D module
    LCD_Init();
    DelayMS(100);
    LCD_LINE(1);
    LCD_STR(Company);
    LCD_LINE(2);
    LCD_STR((unsigned rom char*)"Temp: ");
    //DEFAULTS
    DelayTime = 500;
    MyView = 'F';
    CompSpeed = 0; //Company = 0, Speed = 1
	while(1){
      for(tmp=0;tmp<5;tmp++){
        ADCON0bits.GO = 1;          //Start the conversion
        while(ADCON0bits.DONE);     //Wait until it’s done
        result = ADRESH;            //Load ADRESH into result
        result <<= 8;               //Shift over Result 8 bits to the left
        result |= ADRESL;           //OR in our LOW byte to finish off out INT
        avg[tmp] = result;
        DelayMS(40);
        result = 0;
            result += avg[tmp];
        result /= 5;
        if(result==oldresult) goto tSame;
        DegC = (result*5)/10;
        DegC--;
        DegF = DegC * 9;
        DegF/=5;
        DegF+=32;
        //clear LCD temp buffer
        for(tmp=0;tmp<16;tmp++)
            lcdtmp[tmp] = ' ';
    if(MyView == 'F'){
        lcdtmp[0] = DECtoASCII(DegF,'h');
        lcdtmp[1] = DECtoASCII(DegF,'l');
        lcdtmp[2] = 0xDF;
        lcdtmp[3] = 'F';
        lcdtmp[4] = ' ';
    } else {
        lcdtmp[0] = DECtoASCII(DegC,'h');
        lcdtmp[1] = DECtoASCII(DegC,'l');
        lcdtmp[2] = 0xDF;
        lcdtmp[3] = 'C';
        lcdtmp[4] = ' ';
        LCD_LINE(2);
        LCD_STR2(lcdtmp);
        DelayMS(DelayTime);
        oldresult = result;
tSame:
		if(KeyPORT == MENU){
			DelayMS(10); //Extra Debounce
			MainMenu();
			while(KeyPORT == MENU);
        if(KeyPORT == UP){
            LCD_LINE(1);
            if(CompSpeed == 1){
                CompSpeed = 0;
                LCD_STR(Company);
            } else {
                CompSpeed = 1;
                switch(DelayTime){
                    case 500:
                        LCD_STR(SpeedLIST[0]);
                        break;
                    case 1000:
                        LCD_STR(SpeedLIST[1]);
                        break;
                    case 2000:
                        LCD_STR(SpeedLIST[2]);
                        break;
			while(KeyPORT == UP);
unsigned char DECtoASCII(unsigned char DEC,char part){
unsigned char temp;
unsigned char myData;
    temp = DECtoBCD(DEC);
    if(part == 'l')
        myData = temp & 0x0F;
    if(part == 'h')
        myData = (temp >> 4) & 0x0F;
    myData += 0x30;
    return myData;
unsigned char DECtoBCD(unsigned char DEC){
unsigned char temph;
unsigned char templ;
    templ = DEC % 10;
    temph = DEC / 10;
    myData = (temph << 4) | templ;
    return myData; //Return myData
//// MENU SYSTEM
unsigned char x;
LCD_CLEAR(5);
while(!done){
	for(x=0;x<2;x++){
        LCD_LINE(x+1);
		if(x == POS)
			LCD_DATA('>',1);
		else
			LCD_DATA(' ',1);
        LCD_STR(MainMenuLIST[x]);
		case UP:
			if(POS>0){
				POS--;
				ITEM--;
			break;
		case DOWN:
			if(POS<1){
				POS++;
				ITEM++;
			break;
		case ENTER:
			done = 0xFF;
			break;
	switch(ITEM){
		case 0:
			//Code to toggle C or F
            if(MyView == 'F')
                MyView = 'C';
            else
                MyView = 'F';
			break;
		case 1:
			//Code to jump to new menu system
            SpeedMenu();
			break;
    LCD_LINE(1);
    if(CompSpeed == 0){
        LCD_STR(Company);
    } else {
        switch(DelayTime){
            case 500:
                break;
            case 1000:
                break;
            case 2000:
                break;
    oldresult = 0;
//// SPEED MENU SYSTEM
void SpeedMenu(void){
unsigned char START = 0;
unsigned char x;
LCD_CLEAR(5);
while(!done){
	for(x=0;x<2;x++){
        LCD_LINE(x+1);
		if(x == POS)
			LCD_DATA('>',1);
		else
			LCD_DATA(' ',1);
        LCD_STR(SpeedMenuLIST[(x+START)]);
		case UP:
			if(POS>0){
				POS--;
				ITEM--;
			} else {
				POS++;
				ITEM++;
                START = 0;
			break;
		case DOWN:
			if(POS<1){
				POS++;
				ITEM++;
			} else {
                if(START<1){
                    START = 1;
				    POS--;
				    ITEM--;
			break;
		case ENTER:
			done = 0xFF;
			break;
    //START is used to determine which number we are on plus the LCD #
    ITEM+=START;
	switch(ITEM){
		case 0:
			//Code to set 500mS
            DelayTime = 500;
			break;
		case 1:
			//Code to set 1 Second
            DelayTime = 1000;
			break;
		case 2:
			//Code to set 2 Seconds
            DelayTime = 2000;
			break;
//// BUTTON SYSTEM
	unsigned char temp1;	//TEMP DATA HOLDER
		if(KeyPORT>0){			  //if KeyPORT aka PORTB&0x0F.. the &0x0f will make sure we
								  //return the lower part of port only RB0 to RB3
			temp1 = KeyPORT;	  //Place the lower part of port into temp variable
			while(KeyPORT==temp1);//Like a debounce for button press
			done = 0xFF;		  //Set DONE Var so we know we are complete
	return temp1;				  //Return our temp1 var
I even added the option to show the current update speed by pressing up
That makes it worse, it now does:
"waiting"
press MENU
">option 1"
"option 2"
Press DOWN
"Option 1"
"option 2"
but it made me notice that I had declared POS and X twice when I removed it from this code it did nothing but when I removed it from the previous revision, it was a little bit better:
#define MENU   2
#define UP  3
#define DOWN  4
{"Option 1"},
{"Option 2"},
{"Option 3"}
          done = MENU;
          done = UP;
          done = DOWN;
unsigned char x;
while(!done){
	for(x=0;x<2;x++){
		if(x == POS)
		else
		case UP:
			if(POS>0){
				POS--;
				ITEM--;
			} else {
			break;
		case DOWN:
			if(POS<1){
				POS++;
				ITEM++;
			} else {
        PAGE=1;
			break;
		case MENU:
			done = 0xFF;
			break;
  ITEM+=PAGE;
	switch(ITEM){
		case 0:
                Delay_ms(2000);
			break;
		case 1:
                Delay_ms(2000);
			break;
void main() {
      do {
                case MENU:
                Delay_ms(100);
                MainMenu();
                break;
} while (1);
produces:
"Waiting"
press MENU
">Option 1"
"Option 2"
Press DOWN
"Option 2"
">Option 3"
press UP
">Option 2"
"Option 3"
press UP
">Option 1"
"Option 2"
So it seems to work on the UP key press but not the DOWN
I have also noticed:
which means that RA5 is set as an input but is not being used in the code.
I am using a LVP so RA5 is pulled high all the time would this make a difference?
#define MENU   2
#define UP  3
#define DOWN  4
{"Option 1"},
{"Option 2"},
{"Option 3"}
          done = MENU;
          done = UP;
          done = DOWN;
unsigned char x;
while(!done){
	for(x=0;x<2;x++){
		if(x == POS)
		else
		case UP:
			if(POS>0){
				POS--;
				ITEM--;
			} else {
			break;
		case DOWN:
			if(POS<2){
				POS++;
				ITEM++;
			} else {
        PAGE=1;
			break;
		case MENU:
			done = 0xFF;
			break;
  ITEM+=PAGE;
	switch(ITEM){
		case 0:
                Delay_ms(2000);
			break;
		case 1:
                Delay_ms(2000);
			break;
void main() {
      do {
                case MENU:
                Delay_ms(100);
                MainMenu();
                break;
} while (1);
produces
">Option 1"
"Option 2"
"Option 1"
"option 2"
i think its a hardware issue. Since it works on my side so well..
Can you post a full schematic and if possible zip your entire code and post it here
that is my entire code, since we got the buttons working i havent tried to integrate the ds1820 yet. will draw up a schematic and post
Try This pal:
//REV2
 #define MENU   2
#define UP  3
#define DOWN  4
{"Option A"},
{"Option B"},
{"Option C"}
          done = MENU;
          done = UP;
          done = DOWN;
unsigned char x;
while(!done){
    for(x=0;x<2;x++){
        if(x == POS)
        else
        case UP:
            if(POS>0){
                POS--;
                ITEM--;
            } else {
                if(PAGE>0){
                    POS++;
                    ITEM++;
                    PAGE=0;
            break;
        case DOWN:
            if(POS<1){
                POS++;
                ITEM++;
            } else {
                if(PAGE<1){
                    PAGE = 1;
                    POS--;
                    ITEM--;
            break;
        case MENU:
            done = 0xFF;
            break;
    ITEM+=PAGE;
    switch(ITEM){
        case 0:
            Delay_ms(2000);
            break;
        case 1:
            Delay_ms(2000);
            break;
void main() {
  TRISA = 0b00011100;                 // RA5,RA4,RA3,RA2 are set to input
      do {
                case MENU:
                Delay_ms(100);
                MainMenu();
                break;
} while (1);
