Peter_wadley
I am trying to use Nigels code for driving an LCD with a PIC16F84a instead of a PIC16F628, which is used in his tutorial...
Since the 84a does not have as many (A) pins I wanted to make the connections like this..
RS (pin4 of LCD) goes to A0
RW (pin5 of LCD) goes to A1
E (pin6 of LCD) goes to A2
and as for the 4 data bus bits..
D4 goes to RB0
D5 goes to RB1
D6 goes to RB2
D7 goes to RB3
Here is the code after I have tried modifed it:
Basically nothing happens when this is hooked up![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have a good understanding of the code but I must have goofed somewhere.. any ideas?
P.W
Edit: Im using MPLAB.
D4 goes to RB0
D5 goes to RB1
D6 goes to RB2
D7 goes to RB3
PHP:
;LCD text demo - 4 bit mode
cblock 0x20 ;start of general purpose registers
count ;used in looping routines
count1 ;used in delay routine
counta ;used in delay routine
countb ;used in delay routine
tmp1 ;temporary storage
tmp2
templcd ;temp store for 4 bit mode
templcd2
endc
LCD_PORT Equ 05h
LCD_TRIS Equ 85h
LCD_RS Equ 0x00 ;RS IS ON RA0
LCD_RW Equ 0x01 ;RW IS ON RA1
LCD_E Equ 0x02 ;E IS ON RA2
PORTA Equ 0x05
PORTB Equ 0x06
STATUS Equ 0x03
Z Equ 0x02
PCL Equ 0x02
org 0x0000
Initialise
clrf count
clrf PORTA
clrf PORTB
SetPorts
bsf STATUS,5 ;select bank 1
movlw 0x00 ;make all pins outputs (for portA and portB)
movwf LCD_TRIS
movwf 0x86
bcf STATUS,5 ;select bank 0
call Delay100 ;wait for LCD to settle
call LCD_Init ;setup LCD
clrf count ;set counter register to zero
Message
movf count, w ;put counter value in W
call Text ;get a character from the text table
xorlw 0x00 ;is it a zero?
btfsc STATUS, Z
goto NextMessage
call LCD_Char
call Delay255
incf count, f
goto Message
NextMessage
call LCD_Line2 ;move to 2nd row, first column
Message2
call Text2 ;get a character from the text table
btfsc STATUS, Z
goto EndMessage
call LCD_Char
incf count, f
goto Message2
EndMessage
Stop goto Stop ;endless loop
;Subroutines and text tables
;LCD routines
;Initialise LCD
LCD_Init
movlw 0x20 ;Set 4 bit mode
call LCD_Cmd
movlw 0x28 ;Set display shift
call LCD_Cmd
movlw 0x06 ;Set display character mode
call LCD_Cmd
movlw 0x0d ;Set display on/off and cursor command
call LCD_Cmd
call LCD_Clr ;clear display
retlw 0x00
; command set routine
LCD_Cmd
movwf templcd
swapf templcd, w ;send upper nibble
andlw 0x0f ;clear upper 4 bits of W
movwf LCD_PORT
movwf PORTB ;[COLOR="Red"]; Line added by PW - problem?[/COLOR]
bcf LCD_PORT, LCD_RS ;RS line to 0
call Pulse_e ;Pulse the E line high
movf templcd, w ;send lower nibble
movwf LCD_PORT
call Delay5
retlw 0x00
LCD_CharD addlw 0x30
LCD_Char
movwf templcd
movwf LCD_PORT
bsf LCD_PORT, LCD_RS ;RS line to 1
movwf LCD_PORT
call Delay5
retlw 0x00
LCD_Line1
movlw 0x80 ;move to 1st row, first column
call LCD_Cmd
retlw 0x00
LCD_Line2
movlw 0xc0 ;move to 2nd row, first column
call LCD_Cmd
retlw 0x00
LCD_Line1W
addlw 0x80 ;move to 1st row, column W
call LCD_Cmd
retlw 0x00
LCD_Line2W
addlw 0xc0 ;move to 2nd row, column W
call LCD_Cmd
retlw 0x00
LCD_CurOn
call LCD_Cmd
retlw 0x00
LCD_CurOff
movlw 0x0c ;Set display on/off and cursor command
call LCD_Cmd
retlw 0x00
LCD_Clr
movlw 0x01 ;Clear display
call LCD_Cmd
retlw 0x00
LCD_HEX
movwf tmp1
swapf tmp1, w
andlw 0x0f
call HEX_Table
call LCD_Char
movf tmp1, w
andlw 0x0f
call HEX_Table
call LCD_Char
retlw 0x00
Delay255 movlw 0xff ;delay 255 mS
goto d0
Delay100 movlw d'100' ;delay 100mS
goto d0
Delay50 movlw d'50' ;delay 50mS
goto d0
Delay20 movlw d'20' ;delay 20mS
goto d0
Delay5 movlw 0x05 ;delay 5.000 ms (4 MHz clock)
d0 movwf count1
d1 movlw 0xC7 ;delay 1mS
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
Pulse_e bsf LCD_PORT, LCD_E
nop
bcf LCD_PORT, LCD_E
retlw 0x00
;end of LCD routines
HEX_Table
addwf PCL , f
retlw 0x30
retlw 0x31
retlw 0x32
retlw 0x33
retlw 0x34
retlw 0x35
retlw 0x36
retlw 0x37
retlw 0x38
retlw 0x39
retlw 0x41
retlw 0x42
retlw 0x43
retlw 0x44
retlw 0x45
retlw 0x46
Text addwf PCL, f
retlw 'H'
retlw 'e'
retlw 'l'
retlw 'l'
retlw 'o'
retlw 0x00
Text2 addwf PCL, f
retlw 'R'
retlw 'e'
retlw 'a'
retlw 'd'
retlw 'y'
retlw '.'
retlw '.'
retlw '.'
retlw 0x00
end
P.W
