Lead-Acid Trickle Charger with added features
iONic
Hello all,
I am trying to build a 12V Lead-Acid Trickle Charger, but with some added features.
I'd like a green power on LED and an LED way to monitor the Current drawn.
For example: 1 LED for 20mA, 2 LED's for 40mA, 3 LED's for 80mA, 4 LED's for 160mA, and 5 LED's for 320mA or higher. Actually it might be better to only have 1 of 5 LED's on at any given time.
For the current LED indicator I would suggest a low value resistor in the low side of the charger rail.
An opa across the resistor, the output of the opa driving a LM3914 and LEDs, either in dot/bar mode.
Do you need a hand with the design?
EDIT: this could one way to do it.:)
I had thought about the LM3914 as a posible solution so this could work out nice. Thanks for the schematic and your efforts!
Would this affect the voltage requirments from the transformer(Wall-Wart)??
If you allow about 10mA/LED that should cover the major part of the extra current required.
I would estimate that if the existing wall wart is say, 500/100mA, it should be OK.
You could set the LM3914 for 'dot' mode, thats one LED at 10mA!
