LED Current Ratings
Mr Audioguru, could you please explain this. I don't quite understand.
With a 50% duty-cycle the LED is turned on for half the time and is turned off for half the time so its average power (and average heating) is half and it appears to be dimmed a little.
Ahh, Ok
So if i were to go to a 25% duty cycle, the heat would be a quarter. Is this how it works?
Would the light dim much?
Tom
Ahh, Ok
Yes the heating is reduced as much as the duty-cyle is reduced.
Your vision's response to brightness is not linear, it is logarithmic so you have a very wide range of sensitivity from starlight to sunlight. So 25% will not appear to be dimmed much. 1/10th power appears half as bright. You can see an LED glowing in the dark when its power is much less than 1/1000th.
Ok,
I knew that hearing was logarithmic, but vision I didn't. Well, you learn something new everyday :-)
So I could even get it down to 15% and that would be 15/100ths of the heat. If I didn't mind it getting a little dimmer.
Another thing, should I put a capacitor across the LED? If so what value big, small or really small?
Thanks so much for your help
Tom
Read up on PWM to see some waveforms and how duty-cycle affects the waveform. The amount of time that the wave is "high" is the amount of time that voltage, and therefore current, will be applied to the LED. (or whatever device/component you are feeding)
Also, you can get a bunch of schematics on creating and using PWM with LEDs. A simple 555 timer and a few caps and resistors is all you need. Throw in a potentiometer, and you can change the duty-cycle in real-time. That way you can test your LED to "see" what brightness level you can accept.
You do not want a capacitor across the LED when you PWM it - that will make it dimmer, rather than pulses of high brightness.
If I caused that confusion, I apologize. I was referring to the bypass and timing caps for the 555.
Ok then,
No Caps across the LED.
Is it possible that when the LED is turned on, via PWM, the current will spike and go above the max current rating?
Tom
No, LEDs dont function like motors or other inductive loads.
The PWM signal will average the current.
When LEDs are multiplexed they blink on for only a moment then the next one then the next one etc. So the LEDs have a low duty-cycle which causes their average current to be low and therefore they appear dimmed. So the current is increased until the average current is normal so the LEDs look normally bright. Then the peak current is much higher than the rated max continuous current. That is why the datasheet for most LEDs spec's a max allowed peak current at a certain max on-time.
My ordinary red LEDs are spec'd with a max allowed continuous current of 40mA and a max allowed peak current of 200mA for 100us.
