Led flash in 'c'
poppy2008
Hi
i am new to c,and i know little assembly language
i want to flash the LED one by one from right to left and left to write using 'c ' with some delay.
i am using 'Explorer 16 development board'
in assembly we use rrc,rlc instructions ,the codes are very less.
but i am writing in c ,the program is big ,but this program is working.
my question is how to write this program in simple way?
pls help me
/* LED's ON one by one from left to right and right to left with 0.25 sec delay in PORTA*/
#include <p24FJ128GA010.h>
#define DELAY 15625 //31250,0.5 sec //62500,1 sec delay//
main ()
	//Code goes here
    AD1PCFG = 0xFFFF; 		// all pins are digital
	TRISA = 0xFF00;  	    // bit 0-7 output,bit 8-15 input
	T1CON = 0x8030;  	 	// timer1 on,input clock prescale 256,internal clock(FOSC/2)
	LATAbits.LATA0 = 1;
	TMR1 = 0;
	while(TMR1< DELAY)
	LATAbits.LATA0 = 0;
	LATAbits.LATA1 = 1;
	TMR1 = 0;
	while(TMR1< DELAY)
	LATAbits.LATA1 = 0;
	LATAbits.LATA2 = 1;
	TMR1 = 0;
	while(TMR1< DELAY)
	LATAbits.LATA2 = 0;
	LATAbits.LATA3 = 1;
	TMR1 = 0;
	while(TMR1< DELAY)
	LATAbits.LATA3 = 0;
	LATAbits.LATA4= 1;
	TMR1 = 0;
	while(TMR1< DELAY)
	LATAbits.LATA4 = 0;
	LATAbits.LATA5= 1;
	TMR1 = 0;
	while(TMR1< DELAY)
	LATAbits.LATA5 = 0;
	LATAbits.LATA6= 1;
	TMR1 = 0;
	while(TMR1< DELAY)
	LATAbits.LATA6 = 0;
	LATAbits.LATA7= 1;
//	TMR1 = 0;
//	while(TMR1< DELAY)
//	LATAbits.LATA7 = 0;
	TMR1 = 0;
	while(TMR1< DELAY)
	LATAbits.LATA7 = 0;
	LATAbits.LATA6 = 1;
	TMR1 = 0;
	while(TMR1< DELAY)
	LATAbits.LATA6 = 0;
	LATAbits.LATA5 = 1;
	TMR1 = 0;
	while(TMR1< DELAY)
	LATAbits.LATA5 = 0;
	LATAbits.LATA4 = 1;
	TMR1 = 0;
	while(TMR1< DELAY)
	LATAbits.LATA4 = 0;
	LATAbits.LATA3= 1;
	TMR1 = 0;
	while(TMR1< DELAY)
	LATAbits.LATA3 = 0;
	LATAbits.LATA2= 1;
	TMR1 = 0;
	while(TMR1< DELAY)
	LATAbits.LATA2 = 0;
	LATAbits.LATA1= 1;
	TMR1 = 0;
	while(TMR1< DELAY)
	LATAbits.LATA1 = 0;
	LATAbits.LATA0= 1;
The way I would do this in a loop is,
main ()
unsigned char Mask;
    //Code goes here
    while(1){	                //loop forever
        for(Mask=1;Mask!=0;Mask<<=1){
            LATA=Mask;
            TMR1 = 0;
            while(TMR1< DELAY);
Note that Mask will become zero after being shifted left from 128.
The above is not the conventional way to do this. An easier to understand piece of code is,
        Mask=1;			//start with bit 0
        while(Mask!=0){		//do until bit shifts out the end
            LATA=Mask;		//output it
            TMR1 = 0;		//reset timer
            while(TMR1< DELAY);	//do delay
            Mask=Mask<<1;	//shift mask left 1 place
HTH.
L
thank you so much mike,it looks very simple. i have one question
if i write
while(Mask ==1){		//do until bit shifts out the end
shifting is not working,why? (!=0 ,==1 both are same or different meaning)
Mask is shifted left each time around the loop and so it goes 1,2,4,8,16,32,64,128,0. If Mask is 16 then (Mask!=0) is true whereas (Mask==1) is false.
