Only if they have level shifter built in most not going to work good with signal lower then 3.7 voltsSo my question is( finally): is there a mosfet driver that can reliably be controlled using a 3.3 volt logic signal without using level shifters or micro-soldering on a brand new board to solve their false claims?
Yes, i am realizing that level/logic conversion/shifting may be my best option. When choosing a 3.3v-->5v device, does it matter if its called logic convertor or level shifter? same same? and what does "npn to pnp" mean?Only if they have level shifter built in most not going to work good with signal lower then 3.7 volts
interesting fork, but they've been working on that a long time, and the latest commit is an untested midi script written by chatGPT. that tells me its not ready for prime time, and is likely designed for simple midi to led displays (like lighting up a 60 led strip along a 63-key keyboard.), if it ever works at all.![]()
GitHub - Kuillemaul/WLED-MIDI: Control WS2812B and many more types of digital RGB LEDs with an ESP8266 or ESP32 over WiFi!
Control WS2812B and many more types of digital RGB LEDs with an ESP8266 or ESP32 over WiFi! - Kuillemaul/WLED-MIDIgithub.com
Can i just use one of these little guys?Just remove Optocoupler and replace with a better on on the driver board ones i looked had a Optocoupler that not going to work well at 3 volts they was spec to use 20 mA at 5 volts
At 3 volt your 12 mA probably not going to work well with pwm
