Hey folks,
This is my first serious electronics project (done some soldering before), so bear with me. I want to make an LED grow light for indoor hydroponic herbs (not weed, basil and cilantro mostly). I've done some research, but I want to get some expert advice and help now.
I've got some LEDs on the way, 3 colors that should be 3.5v 290mA, 2.2v 350mA, and 3.2v 300mA. I averaged the voltages and amps to ask the wizard, which told me this:
Solution 0: 7 x 4 array uses 28 LEDs exactly
+----|>|----|>|----|>|----|>|----|>|----|>|----|>|---/\/\/----+ R = 3.3 ohms
each 3.3 ohm resistor dissipates 337.92 mW
the wizard thinks 1W resistors are needed for your application
together, all resistors dissipate 1351.68 mW
together, the diodes dissipate 29568 mW
total power dissipated by the array is 30919.68 mW
the array draws current of 1280 mA from the source.
Will this work with a 24v 3.75A power source?
I would also like to add a fan or two, would that just be another series that needs to add up to 24v and be added to the total current?
Like I said, I'm brand new to this, but I WILL complete this project eventually, so any advice about any later stages of what I'm trying to do will be amazingly helpful.
Thanks!
Thanks!
