Okay i came up with this....
2 transistors. the flasher wire is the current wire used for indicator because it has pulse threw the bike flasher. and 12V be applied from seprated wire only hot when ignition is on. (gonna do that with a simple automotive relay... connect a current wire that is hot when ignition comes on to the electromagnet and make the connection from battery post the the circut on the other side of magnet) So this is what you were talking about right i am not sure about those resistors. Also if everything looks good can you identify all the values of the resistors and the POT and what type of transistors to use,
thanks
Max
thanks
Max
