Flyback said:Do you believe the contents of the attached report evaluates the situation correctly?
Companies such as Forge Europa are producing LED Lights comprising LEDs in parallel without any series limiting resistors being used.
Is this ok?
I just don't believe that LED manufacturers don't provide the same detail your report provides. Please give some examples of detail that you provide that is not provided elsewhere.yes I did write the report. There is no other report about this on the www, and led foundrys wont write about it in the detail required.
I am evaluating paralleled leds without limiting resistors......if this is viable, it will revolutionise the led lighting industry...only one led driver would be needed for potentially hundreds of leds......I am a businessperson evaluating a situation which could benefit us all. I am sure that others than myself will benefit if it is possible
LED manufacturers dont do this, as its too expensive, and just increases led heatingIf the manufacturer designs the LED's with an extra PTC resistance in series with the LED die they will automatically compensate themselves
