Ripped off - again - solar power in Australia
Your correct, solar you can turn off, which is, I guess the problem in Australia. the utility needs to be able to turn them off generation.
Not sure what feathered is? I hear that unloaded wind turbines can get out of hand.
Feathering is just the same as on an aeroplane propeller, you change the pitch of the blades to suit the circumstances of the moment.
There's a middling sized wind generator a couple of hundred yards behind me, and you often see the blades are feathered and not rotating, much of the time when winds are too high.
Interestingly, the generator is actually controlled from Ireland, not even from the UK - and if the power isn't needed, they feather the prop and shut it down.
