With precisely that thought, I had purchased the heating coil/element of a solder iron.
The cut piece (~1 cm) gets hot to the touch, but doesn't glow red with a 12v, 23A battery. It does glow a bit with the 12v 2amps power supply output though. Motorcycle battery does the job too.
It obviously depends on the exact resistance - what voltage and wattage was the element?, and how long was the total wire length in the element?. You also try fuse wire (as it blows it would probably trigger the match?, assuming you have fuse wire in these days of MCB's).
Back in the 70's we were reopening a small club after refurbishment, so my friend and I made some flash powder (never done it before, knew nothing about it), but we got some magnesium powder, and some fire works - we broke the fireworks apart and mixed the gunpowder with the magnesium powder.
Then we placed that in a metal saucer, and ran a piece of fuse wire connected across a mains lead through the pile (which was quite large - and we never tested it, as we had no more magnesium), we placed the saucer on top of one of the 18 inch speaker cabinets, on an asbestos pad (just in case).
I also made a tape, by recording and pieces together - basically the crescendo from 2001AD, and added the explosion from Dark Side Of The Moon (with the VU's bouncing off the stops). We then played this, and my friend plugged the mains lead in as the explosion occurred.
I knew it was happening, no one else did - so I was the far side of the room, with my back to it, eyes closed, hands over my eyes, head down to my knees - and everything went bright white!!!.
Oops - perhaps a little bit too much magnesium!
So I can't complain about your incendiary desires
You need to experiment with different types of wire and different lengths.
