Hi ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I am currently stuck on the following problem: I am using a differential amplifier as a line driver in a single-ended configuration. I want to protect both the input and outputs from eventual lightning surges. I started to look for a solution and I came out with this SLVU2.8 (which is great in terms of board space and pin configuration). My first question is: if I use this TVS will the outputs still be phase reversal protected (as they would be if a current limiting
resistor is used with schottky diodes tied to power supply)? What happens when a lightning strikes? Where do the surge go? Will there be any damage to the PCB if I just apply the application ciruit as it is shown in the datasheet (Protection of a unidirectional line on page 3)? Should I take some other precautions?
My second struggle is with the outputs: do I use the same configuration for each of the outputs as for the input? What happens when something comes back from the transmission line?
I will appreciate any advice or help.
Thank, you.
Thank, you.
