When constructing an inductor wouldn't using litz wire be better? I don't mean beacuse of the standard function of litz wire in increasing efficiency from skin effect. Wouldn't it be better to use it because you can reduce the number of winds that you have to physically wind due to the multiple strands per wire? Also this will reduce the resistence of the inductor which will allow you to drastically reduce the voltage which will greatly reduce the wattage of the inductor since electromagnetic strength is entierly dependent on amps/loops..? Just curious. Thanks again.
