This is yet another tachometer circuit :roll:
I'm using the LM2907N (14 pin; uncomitted tach inputs).
The signal is derived from a normal piece of panel wire cable-tied onto the spark plug lead on my kart engine. I get a very strong signal on the scope (I even tried it on my petrol trimmer, works like a charm).
The spikes measured as follows:
Noise = 4Vp-p (probe setting= x1) Pulses = 40Vp-p (probe setting= x10)
Obviously the signal wire should be hooked up to a voltage divider with say a 1:20 ratio to get the voltage down & to get rid of the noise.I will also ref the inverted input @ 0.5*Vcc, in other words, a open loop comparitor.
:?: Should I just wack a resistor in series with the non-inverted input to limit the current when the signal swings below ground (as per data sheet) or should I use a diode with the anode connected to Gnd to short out negative signal swing?
PS sorry for the lack of a schematic![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
