Carel_Integrated
I've built an 18 x 2CH amp using a TA8205AH IC. Before I started building the basic amp, I tested the chip, with only a speaker, a PSU, wires and the chip itself. I knew that noise levels will be extreme and that it wouldn't work as intended, but after I saw that the chip does at least make noise, I started building it. I'm happy with it now, it just doesn't have enough volume. I used the circuit diagram as the one in the TA8205AH datasheet provided by Toshiba and it worked right away, although I had to make a few adjustments...
Now I'm trying to build an AMP with 2x LM3886 chips, but I have no idea where to begin. Also I don't really know where to find a decent diagram (basic)? I've found a basic one somewhere online & I tried to use the chip without other components (just to test if I can actually hear something, even if it's just noise), but nothing happened. Then I realized that I had tied up Pins 4 & 7 (GND and V-), which was wrong. I've corrected it now and now I have some other problem. The chip is constantly putting out 12V at the output stage, it doesn't even make noise (I'm temporarily using a Switching PSU, just to test with, the final project will use Transformers. The PSU has a -12V, GND & +12V pin). I've tried to use a -24V, GND and +24V supply, but then it's even worse as my speakers are getting 24V this time.
1.) I'm not sure why the chip sends 12V directly to the speaker?
2.) Is there a way to bypass the MUTE function completely? (connect the mute pin to V- maybe?)
3.) Where can I find other schematics / examples of how to just get a basic sound coming from the speakers...? I'll worry about the rest later, but It looks like this chip isn't very easy to configure, and also the datasheet is very difficult to read compared to Toshiba's TAXXXX series.
I've used the Diagram located in the LM3886T datasheet (Typical Application)
TA8205AH Datasheet: **broken link removed**
LM3886T Datasheet: **broken link removed**
ANY help will be gladly appreciated.
