Edit, Found the error. I had SYNC=1!!! Guess I missread the datasheet and as it was an unfamiliar chip I assumed it was something far more complicated. When you see hooves think horses not zebras.
I'm at a loss. I have a 18F26K22 on a breadboard with a RS232 to USB converter and an LED. If I short the RX and TX pins on the pic then my terminal program echoes back my key presses. I can scope the RX pin (RC7) and I see the RS232 signal on the pin. However, the pic just ignores it. I'm hoping that I've missed something stupid and so, here is the code at it's bare minimum.
The LED flashes as it should but the line temp=RCREG1 is never executed and nothing appears on the TX pin.
Just in case, the config code,
C:
#include <xc.h>
#include "Config.c"
unsigned char temp;
int main() {
ANSELC=0; //all digital
OSCCON=0x70; //16MHz
PLLEN=1; //64MHz
//setup timer 2 for 1mS interrupts
T2CON=0x4b; //postscaler 10, pre = 16
PR2=99; //16,000,000/16/100/10 = 1000 = 1mS
TMR2ON=1;
//setup RS232 at 9600 baud
//SYNC=1 BRG16=1 SPBRGx=1666 (0x682)
TXSTA1=0b00110100;
RCSTA1=0b10010000;
BAUDCON1=0b00001000; //brg16=1
SPBRGH1=0x06;
SPBRG1=0x82; //9600 baud
TRISB5=0;
while(1){
if(temp++>250){ //flash LED at 1 Hz
temp=0;
LATB5=!LATB5;
while(!TMR2IF); //wait 2mS
TMR2IF=0;
while(!TMR2IF);
TMR2IF=0;
TXREG1=0x55; //send every 2mS
if(RC1IF)
temp=RCREG1; //breakpoint on this line never breaks
C:
#include <xc.h>
// CONFIG1H
#pragma config FOSC = INTIO67 // Oscillator Selection bits (Internal oscillator block)
#pragma config PLLCFG = ON // 4X PLL Enable (Oscillator multiplied by 4)
#pragma config PRICLKEN = ON // Primary clock enable bit (Primary clock enabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRTEN = OFF // Power-up Timer Enable bit (Power up timer disabled)
#pragma config BOREN = SBORDIS // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
#pragma config BORV = 190 // Brown Out Reset Voltage bits (VBOR set to 1.90 V nominal)
// CONFIG2H
#pragma config WDTEN = ON // Watchdog Timer Enable bits (WDT is always enabled. SWDTEN bit has no effect)
#pragma config WDTPS = 32768 // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = PORTC1 // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = ON // PORTB A/D Enable bit (PORTB<5:0> pins are configured as analog input channels on Reset)
#pragma config CCP3MX = PORTB5 // P3A/CCP3 Mux bit (P3A/CCP3 input/output is multiplexed with RB5)
#pragma config HFOFST = ON // HFINTOSC Fast Start-up (HFINTOSC output and ready status are not delayed by the oscillator stable status)
#pragma config T3CMX = PORTC0 // Timer3 Clock input mux bit (T3CKI is on RC0)
#pragma config P2BMX = PORTB5 // ECCP2 B output mux bit (P2B is on RB5)
#pragma config MCLRE = EXTMCLR // MCLR Pin Enable bit (MCLR pin enabled, RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = OFF // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled if MCLRE is also 1)
#pragma config XINST = OFF // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF // Code Protection Block 0 (Block 0 (000800-001FFFh) not code-protected)
#pragma config CP1 = OFF // Code Protection Block 1 (Block 1 (002000-003FFFh) not code-protected)
// CONFIG5H
#pragma config CPB = OFF // Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
#pragma config CPD = OFF // Data EEPROM Code Protection bit (Data EEPROM not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF // Write Protection Block 0 (Block 0 (000800-001FFFh) not write-protected)
#pragma config WRT1 = OFF // Write Protection Block 1 (Block 1 (002000-003FFFh) not write-protected)
// CONFIG6H
#pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
#pragma config WRTB = OFF // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
#pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protection Block 0 (Block 0 (000800-001FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF // Table Read Protection Block 1 (Block 1 (002000-003FFFh) not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
