Hello all, I am in need of some design advice.
I am designing a low power anemometer. The main hurdle here is that I can work with only a 2.5V supply (with 3V as the absolute maximum because I am running on 2 AA batteries). Also, I need to have a voltage output. So, if I were to look at the output voltage of the anemometer, I can correlate the voltage to a wind speed. I only need to detect wind speeds of roughly 150 fpm to 1200 fpm (sorry I am from the US ). I have toyed with many ideas of how to approach this problem.
First, I thought of using a DC brushless fan to generate voltage. When a wind forces a dc fan to spin, it generates a small but measurable voltage. I thought of somehow correlating wind speed to the output voltage in this way, but I could see no discernable pattern or correlation. Also, the fan was not very sensitive to low wind speeds because of the internal metal coils. I tested this with a 40x40x6mm Sunon DC fan. Anyone have ideas? This would be the most ideal solution for my design, because it requires no extra circuitry to function. All it needs is a DC fan.
My next idea was to build the homemade easter egg anemometer as documented here: https://www.otherpower.com/anemometer.html
However, the problem with this anemometer is that LM2917 frequency-voltage chip they use requires a very high supply voltage. Is there a low power version of this chip? I cannot seem to find a frequency-voltage chip that needs less than a 9V supply.
This is where I am stuck. I have been researching some analog tachometers, but I am not sure how they apply to my design. So my dilemma is this, I need to design an anemometer that outputs a voltage and only uses a 2.5V supply.
Any ideas would be greatly appreciated!
