Low Voltage Enable with Latch
LukeKnepp
Here is my complete circuit
Circuit in LTspice -
ENABLE node voltage is green, input is blue, Q2 base-emitter voltage is red.
The overshoot when C1 starts up the circuit causes too much bas-emitter voltage and fries Q2…
I can lessen C1 to reduce overshoot, but then the circuit does not consistently start up…
I can put a Zener diode on the ENABLE node and everything looks good in this simulation, but if I speed it up, the Zener is not fast enough to save Q2...
Any suggestions or is this just not a good circuit for what I’m trying to do?
Your two-transistor arrangement is pretty much emulating a thyristor - when conduction starts, both device immediately turn on to saturation - or destruction, if the available current is high enough.
Add resistors directly in series with each base to limit the base currents??
