nickelflippr
I've been playing with some tamiya dual gearbox motors mounted on a Tamiya tracked vehicle chassis kit. Thru a mostly trial and error process, some reasonable operation is obtained, using a Pic 16f684, TI 754410 dual h bridge, with a software PWM. The h bridge inputs/outputs are paralleled to handle the 2.1A stall current of the motor, so only driving one side right now.
The problem with the TI 754410 h bridge is that the input motor voltage is from 4.5-36V. So four Ni-mh cells are not going to do the job. Using six Ni-mh cells right now for the breadboard operation, but this is likely to be too heavy.
Found a low voltage part, MPC1550EL from Motorola/Freescale, that is made for 2.5-5.5V operation. The problem with this part is that its in a VMFP package.
Anyone know of a low voltage dual h bridge part, in a more friendly package? A Soic package is about as small as I can solder.
