So I have been doing research for the past year, here and there, on magnetic stirrer / hot plates and have finally committed myself to getting down to business... The reason I want to build my own is simply the matter of cost. Home made is cheap and usually just as efficient.
The questions I have for you guys...
The wire I plan to use is called nichrome and consists of 60% nickel, 26% chromium, and 14% iron which can be bought at enasco.com for only $15.00 plus shipping.
1) -I know that the thinner and shorter the wire the hotter it will get but I need a way to pump up the heat but at the same time control the temperature accurately. I don't know what the parts are called but I would imagine it would be called an amperage / voltage regulator with a knob? I am a noob when it comes to this so please feel free to correct me. lol.
So with a way to amplify the electrical current and then a nother way to control this amplified current I could then use a thicker and longer wire coil. So it would go like this.
[electrical outlet - amplifier - amp/volt regulator knob - nichrome coil]
The amplifier and controller for it is probably why all of the magnetic stirrer hot plates are so expensive online. anyways onto the next question.
Once I have a way to control the heat of the coil from room temperature to 400C I need to figure out a ways to get a magnet right up underneath the heat spinning rapidly on a fan motor which already has three speeds One solution to this is to order a magnetic stirrer and modify it with the above device or I can make a totally custom one. Here is my problem.
When the coil is on there will be electricity passing through it. So I need something that doesn't conduct electricity surrounding it but at the same time I need this electrical insulator to allow a magnetic field to pass through it. A powerful magnet will most likely be used so this most likely wont be a problem. I mostly need help with my first question. Thank you for reading.
Original post restored - DO NOT DELETE YOUR POSTS - moderator.
