Making PICs go faster
I once interfaced a 16F628A (using INTOSC) via its serial port to an FTDI FT230XQ serial to USB adapter chip, but ran into problems at high standard baud rates. As I recall, I couldn't go any higher than about 9600 baud. Since the FTDI chip is capable of non standard baud rates, I changed to something that was an exact SPBRG value, and was able to go up to something like 250kbaud, which was faster than I needed.
I decided to check Microchip's site to find one of the modern PIC's that's pin compatible with the 16F630 (14 pin DIP) that I used in this project. It looks like I can drop in a 16F1703, which has a 32 MHz internal oscillator. That will make two more I/O pins available if I need them, plus more program memory and more variable memory. With way more memory, and variables, and two more I/O pins, I could conceivably add more features to the project without making any significant changes to the PC board.
My favourite pin compatible with the 16F630 is the 16F18326. For development it has all the features that you need. Once developed pick one of the family that meets your needs. It has 7 timers, 4 ccp, ADC, DAC, 16kW program etc.
The enhanced mid-range series are extremely useful, and work well with either assembler or C.
Regardless of how "good" the internal oscillator is, isn't the clock accuracy of them temperature dependent?
It's obviously not as good as a crystal, but you're not losing two I/O pins either :D
But it's plenty good enough for the majority of uses, I've not built a board with a crystal on it for a very long time (with the exception of the occasional 32KHz timer1 crystal :D )
I would imagine you need to run the program as windows XP service pack 2 or just try running the program as administrator... God only knows where the buffer for the write is.. It would more likely be the initial run directory of the pickit2 software that's causing the issue... This is windows user protection system gone haywire... I always think, if you log on YOUR OWN computer, you will be an administrator.. SO WHY DOES IT ALWAYS LOCK YOU OUT!!!!
If Microsoft could go to college for computer science they'd fail every course. What they do and what they have done in the past is not science.
Nice to know about the Pickit 3 requirement Les.
Having a look at the datasheet for the PIC16F1703, the internal high speed oscillator has an accuracy of ±2%; certainly not crystal grade, but decent enough for many things. I'll reiterate that I don't need accuracy, just speed.
That's good to know. I have to order several of those too.
Considering I do a lot of MIDI devices and the MIDI specification allows for an error no greater than 1%, a crystal oscillator is my only option.
Don't even get me started on DMX.
The internal oscillator has a max error of 1% so should work fine for MIDI. If you can use the baud autodetect then it should be spot on.
The whole 18000 series are worth a look. They also have a full 20-bit NCO (Numerically Controlled Oscillator), two or four CLC (Configurable Logic Cell) modules, and other features too numerous to mention. The PPS (Peripheral Pin Select) module can be used to have EUSART and SPI or I2C ports running at the same time. The caveat is that programming a device with this many peripherals and features can be a PITA. For example, check out the little Clock-Gen program below which simply provides a couple of clock signals and an econo-reset signal for a retro 65C02 system.
Cheerful regards, Mike
;    Project: 65C02_Clock                                         *
;       File: 16F18313_Clock.asm                                  *
;     Author: Mike McLaren, K8LH                                  *
;    (C)2016: Micro Application Consultants                       *
;           : All Rights Reserved                                 *
;       Date: 04-Apr-2016                                         *
;    16F18313 Clock-Gen + Econo-Reset for 65C02 (8-MHz crystal)   *
;    produces a 1, 2, 4, or 8 MHz CPU clock and an ACIA clock.    *
;        IDE: MPLABX v3.05                                        *
;       Lang: MPASM v5.62 (absolute addressing mode)              *
        #include p16F18313.inc
        errorlevel -302,-311    ; suppress bank warnings
        list st=off             ; symbol table off
        radix dec
;  config settings                                                ~
 __CONFIG _CONFIG1, _FEXTOSC_HS & _FCMEN_OFF
 ; CLKOUTEN_OFF default
 ; CSWEN_ON     default
 __CONFIG _CONFIG2, _WDTE_OFF & _PPS1WAY_OFF
 ; MCLRE_ON     default
 ; PWRTE_OFF    default
 ; LPBOREN_OFF  default
 ; BOREN_ON     default
 ; BOREN_LOW    default
 ; STVREN_ON    default
 ; DEBUG_OFF    default
 __CONFIG _CONFIG3, _LVP_OFF
 ; WRT_OFF      default
 __CONFIG _CONFIG4, _CP_OFF & _CPD_OFF
;  variables                                                      ~
        cblock  0x70            ; common RAM available any bank
delayhi                         ; DelayCy() subsystem variable
        endc
;  constants                                                      ~
;  assign clock and reset pins (RA0..RA2 inclusive).
PHI0_clk equ    RA0             ; bit index for RA0 (0)
ACIA_clk equ    RA1             ; bit index for RA1 (1)
RESB_out equ    RA2             ; bit index for RA2 (2)
;  associate to "Peripheral Pin Select" output registers.
PHI0_PPS equ    RA0PPS+PHI0_clk ; equ RA0PPS
ACIA_PPS equ    RA0PPS+ACIA_clk ; equ RA1PPS
RESB_PPS equ    RA0PPS+RESB_out ; equ RA2PPS
;  set 'CLKR_div' constant for desired 65C02 clock frequency.
;               6 ->  0.5-MHz (Fosc / 64)
;               5 ->  1.0-MHz (Fosc / 32)
;               4 ->  2.0-MHz (Fosc / 16)
;               3 ->  4.0-MHz (Fosc / 8)
;               2 ->  8.0-MHz (Fosc / 4)
CLKR_div equ    4               ; 2.0-MHz PHI0 CPU clock
;  set 'NCO1_inc' constant for desired ACIA clock output.
;          2517 ->    38400-Hz (  2400 * 16) @ 0.01659%
;          5033 ->    76800-Hz (  4800 * 16) @ 0.00327%
;         10066 ->   153600-Hz (  9600 * 16) @ 0.00327%
;         20133 ->   307200-Hz ( 19200 * 16) @ 0.00169%
;         40265 ->   614400-Hz ( 38400 * 16) @ 0.00079%
;         60398 ->   921600-Hz ( 57600 * 16) @ 0.00004%
;        120796 ->  1843200-Hz (115200 * 16) @ 0.00004%
;        241592 ->  3686400-Hz (230400 * 16) @ 0.00004%
NCO1_inc equ    120796          ; 1.8432-MHz (115200 * 16)
;  K8LH DelayCy() subsystem macro generates four instructions     ~
        radix dec
clock   equ     32              ; 4, 8, 12, 16, 20 (MHz), etc.
usecs   equ     clock/4         ; cycles/microsecond multiplier
msecs   equ     usecs*1000      ; cycles/millisecond multiplier
dloop   equ     5               ; loop size, 5 to ??? cycles
;  -- loop --  -- delay range --  -- memory overhead ----------
;  5-cyc loop, 11..327690 cycles,  9 words (+4 each macro call)
;  6-cyc loop, 11..393226 cycles, 10 words (+4 each macro call)
;  7-cyc loop, 11..458762 cycles, 11 words (+4 each macro call)
;  8-cyc loop, 11..524298 cycles, 12 words (+4 each macro call)
;  9-cyc loop, 11..589834 cycles, 13 words (+4 each macro call)
DelayCy macro   cycles          ; range, see above
    if (cycles<11)|(cycles>(dloop*65536+10))
        error " DelayCy range error "
    else
        movlw   high((cycles-11)/dloop)+1
        movwf   delayhi
        movlw   low ((cycles-11)/dloop)
        call    uLoop-((cycles-11)%dloop)
    endif
        endm
;  reset vector                                                   *
        org     0x0000
v_reset
        bra     setup           ;                                 |00
;  interrupt vector                                               *
        org     0x0004
v_int
        retfie                  ;                                 |??
;  main setup                                                     *
setup
;  turn off analog functions (all I/O will be digital).
        banksel ANSELA          ; bank 03                         |03
        clrf    ANSELA          ; analog off, digital I/O         |03
;  setup data direction for 'output' pins (default 'input').
        banksel TRISA           ; bank 01                         |01
        bcf     TRISA,PHI0_clk  ; set phi0 clock pin as output    |01
        bcf     TRISA,ACIA_clk  ; set acia clock pin as output    |01
        bcf     TRISA,RESB_out  ; set resb reset pin as output    |01
;  clear RESB pin output latch (hold the 65C02 in reset).
        banksel LATA            ; bank 02                         |02
        bcf     LATA,RESB_out   ; RESB_out = '0'                  |02
;  setup Fosc for 32-MHz (external 8-MHz crystal and 4xPLL).
        banksel OSCCON1         ; bank 18                         |18
        movlw   b'00010000'     ; -001---- NOSC[2:0], Ext 4xPLL   |18
                                ; ----0000 NDIV[3:0], Clk Div 1   |18
        movwf   OSCCON1         ; 8-MHz Xtal & 4xPLL -> 32-MHz    |18
stable
        btfss   OSCCON3,ORDY    ; OSC stable? yes, skip, else     |18
        bra     stable          ; loop (wait 'til OSC stable)     |18
;  assign PHI0_clk pin (RA0) and ACIA_clk pin (RA1) resources
;  via 'Peripheral Pin Select'.
        banksel PPSLOCK         ; bank 28                         |28
        movlw   0x55            ; PPS unlock sequence             |28
        movwf   PPSLOCK         ;  "                              |28
        movlw   0xAA            ;  "                              |28
        bcf   PPSLOCK,PPSLOCKED ;  "                              |28
        banksel PHI0_PPS        ; bank 29                         |29
        movlw   b'00011110'     ; assign CLKR (Ref Clock) output  |29
        movwf   PHI0_PPS        ; to the PHI0 clock pin (RA0)     |29
        movlw   b'00011101'     ; assign NCO module output to     |29
        movwf   ACIA_PPS        ; the ACIA clock pin (RA1)        |29
        bsf   PPSLOCK,PPSLOCKED ; all done, lock it up            |28
;  setup CLKR (Reference Clock) module for PHI0 CPU Clock.
        banksel CLKRCON         ; bank 07                         |07
        movlw   0x10|CLKR_div   ; 50% duty cycle & divider bits   |07
        movwf   CLKRCON         ; prep 1, 2, 4, or 8-MHz output   |07
        bsf     CLKRCON,CLKREN  ; enable Reference Clock output   |07
;  setup NCO to generate the ACIA clock.
        banksel NCO1CON         ; bank 08                         |08
;       bcf     NCO1CON,N1PFM   ; fixed duty cycle mode (default) |08
        movlw   b'01'<<N1CKS0   ; NCO1<1:0> = '01' = Fosc         |08
        movwf   NCO1CLK         ; set NCO clock source            |08
        clrf    NCO1ACCL        ; clear 20-bit phase accumulator  |08
        clrf    NCO1ACCH        ;  "                              |08
        clrf    NCO1ACCU        ;  "                              |08
        movlw   low(NCO1_inc)   ; setup 20-bit phase increment    |08
        movwf   NCO1INCL        ;  "                              |08
        movlw   high(NCO1_inc)  ;  "                              |08
        movwf   NCO1INCH        ;  "                              |08
        movlw   upper(NCO1_inc) ;  "                              |08
        movwf   NCO1INCU        ;  "                              |08
        bsf     NCO1CON,N1EN    ; enable NCO module output        |08
;  complete the 65C02 reset cycle.
        DelayCy(20*msecs)       ; wait ~20-msecs                  |08
        bsf     LATA,RESB_out   ; release 65C02 from reset        |02
;  main loop                                                      *
loop
        bra     loop            ; loop forever (until reset)      |02
;  K8LH DelayCy() subsystem 16-bit 'uLoop' timing subroutine      ~
a = dloop-1
    while a > 0
        nop                     ; (cycles-11)%dloop entry points  |??
a -= 1
    endw
uLoop   addlw   -1              ; subtract 'dloop' loop time      |??
        skpc                    ; borrow? no, skip, else          |??
        decfsz  delayhi,F       ; done?  yes, skip, else          |??
        goto    uLoop-dloop+5   ; do another loop                 |??
        return                  ;                                 |??
        end
