Master Slave Clocks with PIC16F887
there should sensor i.e. ADC to detect power failure and store in Memory.
I think i should be stored in EEPROM or internal register of DS1307.
Hello sir,
I have changed some code!
actually i am once writing the time in micro. after that i am removing/re programming the micro by deleting the write function.
so, it run internally the ds1307 chip...
it is working is it fine procedure to run ds1307??
Hello,
The Clock is running internaly i have set the time one and removed the write function for making update from outter switch!
i have place the up and down switch with pull ups at RD4-5 . but it is not responding here is if code parrts
C:
if(RD4==0|| RD5==0){
//Time[] = {0x05, 0x30 ,0x08, 0x22 , 0x10, 0x4, 0x15};
if(RD4==0) // UP MIN HOUR
up_min= up_min+1;
up_hour=up_hour+1;
Time[1]=up_min;
Time[2]=up_hour;
WriteClock(&Time[0]);
if(RD5==0) // UP MIN HOUR
up_min= up_min-1;
up_hour=up_hour-1;
Time[1]=up_min;
Time[2]=up_hour;
hello,
I don't know how to write, need guidance.
C:
  if(RD5==1){
unsigned char a=0;
a=a+1;
if(RD6==1){
unsigned char a=0;
a=a-1;
unsigned char Time[] = {0x11, 0x11 ,0x11, 0x00 , 0x10, 0x4, 0x15};
The function I wrote was this
C:
void WriteClock(char *array)       // Not used
   char x;
   int tmp;
   for(x=0;x<7;x++)
     tmp = array[x] / 10;
     tmp << = 4;
     tmp += array[x] % 16;
     WriteRTC(x,tmp);
This function takes care of writing to the RTC... The array is pointing to the Time[] array.. Whatever is in that array will be written to the RTC... The function also takes care of the BIN / BCD conversion, so you don't need to!!
