I worked in a TV repair shop part time 1970 new TVs came out with new tubes they were called, compactrons.
Can't say I've ever heard that term.
Crazy idea put 2 complete tubes inside 1 glass body I assume to save space tube sockets were mounted on printed circuit boards.
Nothing crazy about it, it makes great sense, and it was done LONG before the 70's - the American 'tube' numbers don't make much sense, but the European 'valve' numbers certainly do.
Such as ECC83 - E means 6.3V heaters, C means triode (so CC = two triodes) and 8 means B9A base (3 means it's different to a 1 or a 2
Likewise PCL85 - P means 300mA heaters, C is triode again, and P is pentode - it was the standard frame valve in B&W TV's for many years.
You even got valves with more than two in the same envelope.
Essentially it was a precursor for integrated circuits, creating composite devices for specific purposes - and back in the day, that purpose was radio.
That only lasted 3 years then circuit boards were plug in with transistors. To repair a TV unplug the bad circuit board and replace it. Tubes were gone from TVs by the end of 1973 except for the 1B3GT high voltage tube. OH.....almost forgot picture tube is a tube also.
Valves ceased to be used in the UK well before the US, and we never had transistor sets with valve EHT rectifiers. As far as repairs went, you simply repaired the boards rather than replacing them - it made in home service a lot easier. The outside engineers would fit an exchange board, and bring the old one back for me to repair - to that end I build two test jigs, one for Thorn 3000 panels, the other for RBM A823 series - the two most popular chassis's we sold.
