philba said:Probe construction is tricky, though. Use teflon insulated wire - you wont get muck and slime growing on it (changes capacitance). You should also make the wire fairly rigid (use tension) so that it retains it's shape after you have calibrated.
When the water falls below the probe there will be a change in capacitance. If one looks for that rather rapid change (compared to slime or mineral deposits) then within some limits the actual capacitance does not matter.
No calibration.
