hi Al,
Try this test7.hex.
On Sw3 position, the DS18S20 temperature is displayed,also the Fan State, Ton and Toff temperatures.
Add a 4k7 pull up resistor on PORTC.7 [ to +5v] , add a n/o push switch from pin PORTC.7 to 0V.
To Set up your Fan On/Off temperatures, select Sw pos3 and then press and hold the push switch. [the push switch allows you to change the settings, while its pushed]
Set the Ton using the set +15Vvar pot and the Toff using the -15Vvar pot.
These are the controls on the front that you use set the V outputs of the variable supplies.
Once set release the push button.
The settings are stored in the PIC's EEPROM and recalled at power up.
Sw4 is still unused.
Eric
EDIT:
Does your PC have a serial RS232 connector.??
Try this test7.hex.
Eric
EDIT:
