Micro controller Programming
C:
#include <Wire.h>                       // For some strange reasons, Wire.h must be included here
#include <DS1307new.h>
// DEFINE
// VARIABLES
uint16_t startAddr = 0x0000;            // Start address to store in the NV-RAM
uint16_t lastAddr;                      // new address for storing in NV-RAM
uint16_t TimeIsSet = 0xaa55;            // Helper that time must not set again
// SETUP
void setup()
  pinMode(2, INPUT);                    // Test of the SQW pin, D2 = INPUT
  digitalWrite(2, HIGH);                // Test of the SQW pin, D2 = Pullup on
  Serial.begin(9600);
   PLEASE NOTICE: WE HAVE MADE AN ADDRESS SHIFT FOR THE NV-RAM!!!
                  NV-RAM ADDRESS 0x08 HAS TO ADDRESSED WITH ADDRESS 0x00=0
                  TO AVOID OVERWRITING THE CLOCK REGISTERS IN CASE OF
                  ERRORS IN YOUR CODE. SO THE LAST ADDRESS IS 0x38=56!
  RTC.setRAM(0, (uint8_t *)&startAddr, sizeof(uint16_t));// Store startAddr in NV-RAM address 0x08
   Uncomment the next 2 lines if you want to SET the clock
   Comment them out if the clock is set.
   DON'T ASK ME WHY: YOU MUST UPLOAD THE CODE TWICE TO LET HIM WORK
   AFTER SETTING THE CLOCK ONCE.
//  TimeIsSet = 0xffff;
//  RTC.setRAM(54, (uint8_t *)&TimeIsSet, sizeof(uint16_t));
  Control the clock.
  Clock will only be set if NV-RAM Address does not contain 0xaa.
  DS1307 should have a battery backup.
  RTC.getRAM(54, (uint8_t *)&TimeIsSet, sizeof(uint16_t));
  if (TimeIsSet != 0xaa55)
    RTC.stopClock();
    RTC.fillByYMD(2011,4,8);
    RTC.fillByHMS(22,7,0);
    RTC.setTime();
    TimeIsSet = 0xaa55;
    RTC.startClock();
  else
    RTC.getTime();
   Control Register for SQW pin which can be used as an interrupt.
  RTC.ctrl = 0x00;                      // 0x00=disable SQW pin, 0x10=1Hz,
                                        // 0x11=4096Hz, 0x12=8192Hz, 0x13=32768Hz
  RTC.setCTRL();
  Serial.println("DS1307 Testsketch");
  Serial.println("Format is \"hh:mm:ss dd-mm-yyyy DDD\"");
  uint8_t MESZ;
  MESZ = RTC.isMEZSummerTime();
  Serial.print("MEZ=0, MESZ=1 : ");
  Serial.println(MESZ, DEC);
  Serial.println();
// MAIN (LOOP)
void loop()
  RTC.getTime();
  if (RTC.hour < 10)                    // correct hour if necessary
    Serial.print("0");
    Serial.print(RTC.hour, DEC);
  else
  Serial.print(":");
  if (RTC.minute < 10)                  // correct minute if necessary
    Serial.print("0");
    Serial.print(RTC.minute, DEC);
  else
  Serial.print(":");
  if (RTC.second < 10)                  // correct second if necessary
    Serial.print("0");
    Serial.print(RTC.second, DEC);
  else
  Serial.print(" ");
  if (RTC.day < 10)                    // correct date if necessary
    Serial.print("0");
    Serial.print(RTC.day, DEC);
  else
  Serial.print("-");
  if (RTC.month < 10)                   // correct month if necessary
    Serial.print("0");
    Serial.print(RTC.month, DEC);
  else
  Serial.print("-");
  Serial.print(RTC.year, DEC);          // Year need not to be changed
  Serial.print(" ");
  switch (RTC.dow)                      // Friendly printout the weekday
    case 1:
      Serial.print("MON");
      break;
    case 2:
      Serial.print("TUE");
      break;
    case 3:
      Serial.print("WED");
      break;
    case 4:
      Serial.print("THU");
      break;
    case 5:
      Serial.print("FRI");
      break;
    case 6:
      Serial.print("SAT");
      break;
    case 7:
      Serial.print("SUN");
      break;
  Serial.print(" seconds since 1.1.2000:");
  Serial.print(RTC.time2000, DEC);
  uint8_t MESZ = RTC.isMEZSummerTime();
  Serial.print(" MEZ=0, MESZ=1 : ");
  Serial.print(MESZ, DEC);
  Serial.print(" - Address in NV-RAM is: ");
  RTC.getRAM(0, (uint8_t *)&lastAddr, sizeof(uint16_t));
  Serial.print(lastAddr, HEX);
  lastAddr = lastAddr + 1;              // we want to use it as addresscounter for example
  RTC.setRAM(0, (uint8_t *)&lastAddr, sizeof(uint16_t));
  if (TimeIsSet == 0xaa55)              // check if the clock was set or not
    Serial.println(" - Clock was set!");
  else
    Serial.println(" - Clock was NOT set!");
  delay(1000);                          // wait a second
Then the ram location 54 isn't being updated.
Like I said before Adafruits RTClib seems to be a better choice...
You need to recompile the code without this code
C:
    RTC.stopClock();
    RTC.setTime();
    TimeIsSet = 0xaa55;
    RTC.startClock();
  else
    RTC.getTime();
Then it will be okay...
C:
// DEFINE
// VARIABLES
// SETUP
void setup()
  Serial.begin(9600);
  Control the clock.
    RTC.getTime(); // <---- Just this line
  RTC.setCTRL();
  uint8_t MESZ;
  Serial.println();
// MAIN (LOOP)
void loop()
  RTC.getTime();
    Serial.print("0");
  else
  Serial.print(":");
    Serial.print("0");
  else
  Serial.print(":");
    Serial.print("0");
  else
  Serial.print(" ");
    Serial.print("0");
  else
  Serial.print("-");
    Serial.print("0");
  else
  Serial.print("-");
  Serial.print(" ");
    case 1:
      break;
    case 2:
      break;
    case 3:
      break;
    case 4:
      break;
    case 5:
      break;
    case 6:
      break;
    case 7:
      break;
  else
Result for this coding....
before modifying the code-once the clock sets the time starts to run but when the external power turned off the clock reset to 0.0.0
After the modification of code the clock displays 0.0.0 only...
Thanks!!! Rogers for your support...I Solved the RTC problem...The problem was due to the frequent interrupt in power going to 3rd pin of DS1307.
