Rippey574
I have this power supply my grandfather started and I have finished it. I am trying to figure the rating for transformer, they are military. I understand easily the wiring and markings... except for the way the have listed the max W.V. and secondary amperage. See the pic...
If you notice the MAX W.V. is at the center, so does it represent the max W.V. for the primary or secondary? If its secondary is that for 6.3-6.3 or the 12.6?
Also the the secondary winding shows the amperage under the center tap, so is this a 20 amp if i use the 12.6 or is it 10 amp,.,. Or could it be used as a 2 10 amps at 6.3?
Other information, they are sealed (presumed) oil filled.
Primary is set up to 115 with both primary's using 110 (1&4 Hot 2&3 Neutral)
Well back to fixing the regulator and drying the stain.
