Menticol
Active Member
Seems counter to Paschen’s Law. Do you have a reference?
Ken
Yes sir! I got it
Aeronautica
Tomo 4
Electricidad en Los aviones
M. Plaza Fernandez
ISBN:84-283-1080-7
Paninfo 1986
Ken
Water behaves differently in gas form, also pure water is a very good insulator so it's no surprise to me. It's only when condensation forms and dissolved ionic compounds start to cause tracking does humidity cause problems with HV circuits.Oops! Misread the chart. Still seems counter intuitive. Increase in humidity also increases breakdown voltage. Now throw a bucket of water an high voltage circuit.
Ken
Interesting discussion. Keep in mind that the spec for the transformer was based on a fixed set of conditions including input voltage and load on the secondary. Manufacturing tolerances along with slight departures from design conditions might explain why 7 volts when you expect 6.3 volts. If your measurements were no load or open circuit you might try adding some kind of load.
What is this power supply for? Part of an antique radio or something?
I wonder if water vapour is a better insulator than air? This evidence would suggest that this is the case.
