Misim DE Pic simulator
Thanks, I'm still simulating yet, and have not committed the design to hardware, but will add pull-ups when I do.
As its still in simulation, there is no ULN2803 connected, I'm just looking at the IO pins and the simulated stepper in Oshonsoft.
Ok, so what I did was copy the basic logic from your ASM file, ans re-wrote it in Oshonsoft Basic (Pic10 Simulator IDE). This works in the simulator. Of course, I was not sure of polarity of the buttons, so I assumed the "run" was on when pin is grounded. As someone else pointed out, you may have to invert the output pins if using specific drivers. Also, if the motor turns the wrong way, you can either change the direction logic or swap the wires on the motor.
I'm ignoring the OSCCAL value in this code, as default is in the "middle", and won't affect the timing too much (I hope...)
Basic code:
Define CONFIG = 0x000a
'__CONFIG   _MCLRE_OFF & _CP_OFF & _WDT_OFF & _IntRC_OSC
';    control a small stepper motor with a 12F509
';    There are two controls, run/stop And direction
';    The motor steps when the run button is depressed (zero)
';    If the direction button is pressed
';    the direction is reversed
Dim index As Byte
Dim mask As Byte  'Output bit pattern
'; GP3 controls run/stop
'; GP5 controls direction
ConfigPin GPIO = Output
ConfigPin GPIO.3 = Input
ConfigPin GPIO.5 = Input
Symbol run_btn = GPIO.3
Symbol dir_btn = GPIO.5
index = 0
loop:
'check For run/stop button
If run_btn <> 0 Then Goto loop  'Run if = zero
If dir_btn = 1 Then  'Button high
index = index - 1  'less than zero goes to 255 in Oshonsoft
If index > 7 Then index = 7
Goto sendit
Endif
If dir_btn = 0 Then  'Button low
index = index + 1
If index > 7 Then index = 0
Endif
sendit:
Call stepm()
GPIO = mask
WaitMs 10
Goto loop
End
'; routine To get Step value index
Proc stepm()
mask = LookUp(%00000001, %00000101, %00000100, %00000110, %00000010, %00010010, %00010000, %00010001), index
End Proc
As MPASMWIN code (generated by Oshonsoft compiler)
    list p=12f509
    #include <p12f509.inc>
    radix dec
; Compiled with: PIC10 Simulator IDE v2.51
; Microcontroller model: PIC12F509
; Clock frequency: 4.0MHz
    R0L EQU 0x007
    R0H EQU 0x008
    R4L EQU 0x00F
    R4H EQU 0x010
    R0HL EQU 0x007
    R4HL EQU 0x00F
    RTRIS6 EQU 0x009
    ROPTION EQU 0x00A
;       The address of 'index' (byte) (global) is 0x00B
;       The address of 'mask' (byte) (global) is 0x00C
;       The address of 'run_btn' (bit) (global) is 0x006,3
;       The address of 'dir_btn' (bit) (global) is 0x006,5
    ORG 0x0000
    MOVWF OSCCAL
    CLRF FSR
    MOVLW 0xFF
    MOVWF RTRIS6
    MOVWF ROPTION
    BCF STATUS,6
    BCF STATUS,5
    GOTO L0004
_bootL0003:
    GOTO L0003
_bootDL02:
    GOTO DL02
_boot_lookup_lab_0001:
    GOTO _lookup_lab_0001
; LookUp Table: (%00000001, %00000101, %00000100, %00000110, %00000010, %00010010, %00010000, %00010001)
_lookup_lab_0001:
    ADDWF PCL,F
    RETLW 0x01
    RETLW 0x05
    RETLW 0x04
    RETLW 0x06
    RETLW 0x02
    RETLW 0x12
    RETLW 0x10
    RETLW 0x11
; User code start
L0004:
; 1: Define CONFIG = 0x000a
; 2: '__CONFIG   _MCLRE_OFF & _CP_OFF & _WDT_OFF & _IntRC_OSC
; 3:
; 4:
; 5: ';    control a small stepper motor with a 12F509
; 6:
; 7:
; 8: ';    There are two controls, run/stop And direction
; 9: ';    The motor steps when the run button is depressed (zero)
; 10: ';    If the direction button is pressed
; 11: ';    the direction is reversed
; 12:
; 13: Dim index As Byte
; 14: Dim mask As Byte  'Output bit pattern
; 15: '; GP3 controls run/stop
; 16: '; GP5 controls direction
; 17:
; 18:
; 19: ConfigPin GPIO = Output
    CLRW
    MOVWF RTRIS6
    TRIS 6
; 20: ConfigPin GPIO.3 = Input
    BSF RTRIS6,3
    MOVF RTRIS6,W
    TRIS 6
; 21: ConfigPin GPIO.5 = Input
    BSF RTRIS6,5
    MOVF RTRIS6,W
    TRIS 6
; 22:
; 23: Symbol run_btn = GPIO.3
; 24: Symbol dir_btn = GPIO.5
; 25:
; 26:
; 27: index = 0
    CLRF 0x00B
; 28:
; 29: loop:
L0001:
; 30:
; 31: 'check For run/stop button
; 32: If run_btn <> 0 Then Goto loop  'Run if = zero
    BTFSS 0x006,3
    GOTO L0005
    GOTO L0001
L0005:
; 33:
; 34:
; 35: If dir_btn = 1 Then  'Button high
    BTFSS 0x006,5
    GOTO L0006
; 36: index = index - 1  'less than zero goes to 255 in Oshonsoft
    DECF 0x00B,F
; 37: If index > 7 Then index = 7
    MOVLW 0x07
    MOVWF R0L
    MOVF 0x00B,W
    SUBWF R0L,W
    BTFSC STATUS,C
    GOTO L0007
    MOVLW 0x07
    MOVWF 0x00B
L0007:
; 38: Goto sendit
    GOTO L0002
; 39: Endif
L0006:
; 40:
; 41: If dir_btn = 0 Then  'Button low
    BTFSC 0x006,5
    GOTO L0008
; 42: index = index + 1
    INCF 0x00B,F
; 43: If index > 7 Then index = 0
    MOVLW 0x07
    MOVWF R0L
    MOVF 0x00B,W
    SUBWF R0L,W
    BTFSC STATUS,C
    GOTO L0009
    CLRF 0x00B
L0009:
; 44: Endif
L0008:
; 45:
; 46: sendit:
L0002:
; 47: Call stepm()
    CALL _bootL0003
; 48:
; 49: GPIO = mask
    MOVF 0x00C,W
    MOVWF GPIO
; 50:
; 51: WaitMs 10
    MOVLW 0xE6
    MOVWF R4L
    MOVLW 0x03
    MOVWF R4H
    CALL _bootDL02
; 52:
; 53: Goto loop
    GOTO L0001
; 54: End
L0010:    GOTO L0010
; 55: '; routine To get Step value index
; 56:
; 57: Proc stepm()
L0003:
; 58: mask = LookUp(%00000001, %00000101, %00000100, %00000110, %00000010, %00010010, %00010000, %00010001), index
    MOVF 0x00B,W
    CALL _boot_lookup_lab_0001
    MOVWF 0x00C
; 59: End Proc
    RETLW 0x00
; 60:
; 61:
; 62:
; 63:
; End of user code
L0011:    GOTO L0011
; Delay Routine Byte
; minimal routine execution time: 10µs
; routine execution time step: 3µs
; maximal routine execution time: 772µs
DL01:
    DECFSZ R4L,F
    GOTO DL01
    RETLW 0x00
; Delay Routine Word
; minimal routine execution time: 17µs
; routine execution time step: 10µs
; maximal routine execution time: 655367µs
DL02:
    MOVLW 0x01
    SUBWF R4L,F
    CLRW
    BTFSS STATUS,C
    IORLW 0x01
    SUBWF R4H,F
    BTFSS STATUS,C
    RETLW 0x00
    GOTO DL02
; Waitms Routine
W001:    MOVLW 0x01
    SUBWF R0L,F
    CLRW
    BTFSS STATUS,C
    IORLW 0x01
    SUBWF R0H,F
    BTFSS STATUS,C
    RETLW 0x00
    MOVLW 0x61
    MOVWF R4L
    MOVLW 0x00
    MOVWF R4H
    CALL _bootDL02
    GOTO W001
; Oscillator calibration value
    ORG 0x03FF
    MOVLW 0xFE
; Configuration settings
    ORG 0x0FFF
    DW 0x000A
; End of listing
    END
