So I'm going to order a **broken link removed** But I need the on and off times to both be adjustable from around .5 seconds to 5 seconds. I also want to use larger Pots so I can install it in a project box with knobs to adjust. Whats Pots will I need. They should both me the same right?
I would look at the value of the pots on the PCB when it arrives, if you use remote pots [panel mounted] either get the exact same values or a 'sub multiple' of their values.
