RoboWanabe
Hello.
I have been working on a hovercraft project on and off for some time now and i managed to get the circuit working perfectly and then i blew a few components which id like help finding the problem? But other than that its finished and i just need to work on the actual hovercraft its self i.e. base and curtain for the air cushion. So first i will layout my plan and the problems ive encounterd and once its finished it can be used by every one![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
1) Ciruit diagram
2) My bits and pices
3) My design
plan
So first the main part is the circuit for the hovercraft which i have attached. You will see that i have used a psoc microcontroller for the brain of the craft but this can be changed to a micro of your choice with the same capablities. I am then using two fans. One for the center fan pushing air into the cushion and one attached to a servo to control the movement of the craft. To control these devices you can use a pwm signal from the microcontroller.
To communicate with the craft i am using an ifra red reciver module but i would like to discuss changeing this to Radio controlled for greater distance?
Problems so far?
1) I have broke the two voltage regulators used to power the psoc and the servo. One has stopped outputting completly and the other has a reduced voltage at 2.33v
2) i have blown one of the MOSFETS used to control the fans. saw a pooof of smoke :O
i would like to point out that i am using heat sinks on the MOSFETS and voltage regulators.
I could do with help solveing these problems?
So thats all i can think of including at moment but if there is anything else that you dont understand please ask
or any improvements please share.
Thank you![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
1) Ciruit diagram
3) My design
plan
Problems so far?
Thank you
