Hello everyone, I would be very grateful if I could have some advice regarding my project.
My task is to connect the HV battery of a plug in series hybrid vehicle to the motor using the appropriate converter. I will need to boost the voltage from approximately 280V to 700V. This connection needs to be bidirectional because the motor is operating as a generator during regenerative braking and needs to charge the battery back. However the generator's output is Ac so I will need an Ac/dc inverter as well.
the last part is to connect another generator driven by the Internal Combustion Engine to charge the battery but also with the ability to drive the motor directly.. This will need another ac/dc inverter.
For the first part I was thinking of an isolated bidirectional dc-dc converter followed by a buck boost. I would like to ask if you know any literature that give a similar solution to this problem, preferably sources that provide all the relevant equations.
Also I would be pleased if I could find some relevant simulations of the above converters in Simulink.
I can provide the vehicle's schematic which shows all the relevant connections and also the simulink files of the motor and the generators upon request, if you need it to offer any advice.
Thanks a lot in advance!
