Hi, im looking to add both a monostable and an A stable into a circuit to make an LED flash on and off and then keep the LED on longer when an input is triggered but ive been told many different things.
What i need to know is do i:
Run the output of the monostable into the A stable input, then use the A stable output to power the LED.
Run the output of the monostable to the LED and make the A stable seperate to the rest of the circuit, wiring the output of that to the LED also. (2 sub-systems running to same LED)
Use the output of the monostable as the A stable -ve rail and then use the output of the A stable to power LED.
Any help will be greatly appreciated!
