More computer fan sillyness
If I remember correctly, the transistor would pass the "10 second test" with only one of those small heatsinks that look like an aluminum IC.
Of course you could just use a small 1 x 2 inch scrap of alluminum.
( the 10 second test is - can you touch it for 10 seconds without cursing )
for your fan, I dont think will need much of a heatsink, something like this will do:
https://www.futurlec.com/Heatsinks/TO220S.shtml
since at lower speeds, the transistor is not on all the time, so on average the heat production is lower.
If you go the LM317 route, you will need a heatsink, like above picture, being on all the time, heat production is steady.
You can make your own voltage regulator with an op-amp driving a MOSFET. Either N-channel or P-channel will work, you would just change the output direction. This solution has no minimum regulator voltage dropout.
If the input is known to be a regulated 12V, you don't need a zener diode to create a known voltage, a resistive divider will do. Compare against the output voltage, and include a cap to slow down the feedback response a lot to prevent oscillation.
sounds great, but I don't really get it... :? Don't suppose someone could draw a quick circuit diag for me...? *smiles angelicly*
bmcculla and ante, both very useful, but I was hoping not to use any unusal parts, due the the high shipping costs of places like RS.
Cheers Zevon8, that was what I wanted to know.
Tim,
An Op-Amp and a MOSFET is OK, if you want to create heat and loss of energy! You need PWM regulation to overcome this.
Ante :roll:
lol, no that wasn't what I was going for...
I have decided to go with PWM for one fan, and low dropout regulator with a switch to go to full voltage for the other fan (a la the diag earlier in this thread)
Thanks for all the suggestions guys, I really do appreciate having a choice
Cheers,
Tim
