dreamproject
Hi all,
Could anyone review the code for programming the LM629 that I have written ?. I have tried to follow the sample code given in the programming guide but it does not seem to work . Could anyone possibly review the code ? Possibly some one who has worked with the 629 before .This is written in PIC C . I have also included a schematic of my circuit . Could any one review the circuit for errors . Please find below the links that i've used to help me in my design . Thanks a ton for your time and effort.
Links:
1. **broken link removed**
2. **broken link removed**
3. **broken link removed**
4. **broken link removed**
5. **broken link removed**
// **** Kindly maximize the screen , (c) D.Ajay kumar , March , 2005 ****
// This Program is written in PIC C to interface a PIC16F877 to a LM629 , The program is expected to execute the following
// operation ," Independent of the current resting position of the motor shaft , the shaft will complete thirty revolutions
// in the reverse direction . Total time for the move is fifteen seconds. Total time for accn and deceleration is five secs"
// ** ---- This system uses a 2500 cpr encoder ---- **
// Total counts for this position 2500 cpr x 4 counts/cycle = 10000 counts / rev.
// 10000 x 30 rev = 300000 counts
// 300000/5 = 60000 counts during acceleration and deceleration
// 60000/2 = 30000 counts during acceleration
// Sample perion of system = 2048 x (1/6x10e6) = 341 x 10e-6 seconds/sample. ---- note : 6 MHz clock ----
// The number of samples during accn. (and deceleration) = 2.5 secs / (341x10e-6) = 7332 samples during accn/ decleration.
// s=ut + 1/2 at^2
// a=2s/t^2 = (2 x 30000 counts) / (7332 samples)^2 = 0.00111 counts / sample^2
// Total counts travelled at max velocity is 4/5th of total counts travelled
// (4x 300000)/5 = 240000 counts.
// Number of samples at maximum velocity 10 seconds / (341 x 10e-6) = 29325 samples.
// Using counts/sample velocity is found : 240000/29325 = 8.184 counts / sample.
// Scale acceleration values: 0.00111 x 65536 = 72.744 counts /sample^2
// Scale velocity values : 8.184 x 65536 = 536346.624 counts/sample.
// Round values to the nearest integer:
// Acceleration = 73 = 00 00 00 49 hex counts/sample ^2 ----------------------------------------------(1)
// Velocity = 536347 = 00 08 2F 1B hex counts/sample ----------------------------------------------(2)
// Position =-300000 = FF FB 6C 20 hex counts ----------------------------------------------(3)
#include "C:\pic\Examples\motorfin.h"
#byte TRISB=0x86 // Initialize PORTB
#byte TRISD=0x88 // Initialize PORT D
#byte PORTB=0x06 // Set up PORT B
#byte portd=0x08 // Set up PORT D
#bit rst=0x08.7 // Define RESET pin to PORT B7
#bit ps=0x08.6 // Define Port Select to PORT B6
#bit wr=0x08.5 // Define Write to PORT B5
#bit rd=0x08.4 // Define Read to PORT B4
#bit RB0=0x06.0 // Define RB0 (busy-bit pin)
void init_mod(void);
void filter_mod(void);
void busy_bit(void);
void status_check(void);
void out_c(short);
void out_d(short);
int sw;
void main()
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(FALSE);
setup_psp(PSP_DISABLED);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
while(1)
TRISD=0x00; // Set PORT D as INPUT
init_mod(); // Call Initialize function
filter_mod(); // Call Filter function
out_c(0x1f); // Call out_command module and load the trajectory parameters input buffers
busy_bit(); // Call busy bit check module
out_d(0x00); // Call out data module and output HB of trajectory control word
out_d(0x2b); // All three parameters (pos,vel,acc) will be loaded and all are relative
out_d(0x00); // Accn. data HIGH word HB, refer note ......(1)
out_d(0x00); // Accn. data HIGH word LB
out_d(0x00); // Accn data LOW word HB
out_d(0x49); // Accn data LOW word LB
out_d(0x00); // Vel. HIGH word HB, refer note ............(2)
out_d(0x08); // Vel. HIGH word LB
out_d(0x2f); // Vel. LOW word HB
out_d(0x1b); // vel. LOW word LB
out_d(0xff); // Pos. HIGH word HB, refer note ............(3)
out_d(0xfb); // Pos. HIGH word LB
out_d(0x6c); // Pos. LOW word HB
out_d(0x20); // Pos. LOW word LB
out_c(0x01); // STT issued to execute trajectory
// ** BUSY BIT CHECK MODULE ** //
busy_bit()
// ** CS pin is permanently grounded (Low) **
TRISB=0xff; // Set PORT B as OUTPUT
portd = 0xFF; // Output '11111111' on PORT D
ps=0; // Set PS=0
rd=0; // Set RD=0
while(RB0); // Wait till Busy_bit pin is set (RB0)
ps=1; // Set PS=1
rd=1; // Set RD=1
portd = 0xFF; // Output '00000000' on PORT D
// ** INITIALIZATION MODULE ** //
init_mod()
portd = 0xFF;
begin: // Label
rst=0b0; // Set Reset Low
delay_ms(1); // Call Delay 1 ms.
rst=0b1; // Set Reset High
delay_ms(3); // Call Delay 3 ms.
status_check(); // Call Status Check function
// Check if Status Word is hex 'c4' or '84'
if(!(sw==0xc4 || sw==0x84)) goto begin;
else
out_c(0x1d); // Tells which Interrupts to reset as indicated by zero's in the next data word
out_d(0x00); // Don't Care data.
out_d(0x00); // All interrupts will be reset
// Check if status word is hex 'c0' or '80'
if(!(sw==0xc0||sw==0x80))
goto begin;
// ** FILTER PROGRAMMING MODULE ** //
out_c(0x1e); // LFIL command - initiates loading filter co-efficients.
out_d(0x00); // Filter control word , indicates which values Kp,Ki,Kd,Il will be loaded
out_d(0x0e); // selects that kp,ki,kd values will be loaded
out_d(0x00); // kp values 8 bit HB
out_d(0x0a); // LB
out_d(0x00); // ki values 8 bit HB
out_d(0x00); // LB
out_d(0x00); // kd values 8 bit HB
out_d(0x00); // LB
out_c(0x04); // Transfer new filter co-efficients to Working register
// ** DATA OUT FUNCTION ** //
out_d(int dat)
TRISB=0xff; // Set PORT B as outputs
ps=1; // Set PS high
rd=1; // Set RD high
wr=0; // Set WR low
PORTB=dat; // Output 'dat' on PORT B
wr=1; // Set WR high for sending next byte
// ** COMMAND OUT FUNCTION **//
out_c(int com)
ps=0; // Set PS low
wr=0; // Set WR low
PORTB=com; // Output 'com' on PORT B
// ** STATUS CHECK FUNCTION ** //
status_check()
portd = 0xFF; // Set PORT D as outputs
ps=0; // Set PS low
rd=0; // Set RD low
delay_ms(1); // Call Delay for 1 ms
sw=PORTB; // Store PORTB value in 'sw'
Links:
