Here is the link to the IC
www.fairchildsemi.com/ds/74/74F579.pdf
also see this
If I could Utilize these IC as two BCD counter My problem would be solved!
I would think that trying convert the 8 bit binary counter to 2*BCD is not feasible.
There are more 'elegant' ways to get the mux method you require.
Since I can't find the tri-state buffers, I am trying to make my own!
Will using A bc557 NPN transistor with its base as the enable pin, work? Look at this
i suggested to use 4016, or 4066 IC as a switching multiplexer, did you check it in your local store??
Noone answered my question, Wouldn't using the transistor as the switch do the job?, I have lots of transistors waiting!!
