Hi guys,
I'm learning electronics on my own and wanted to make a megafone using a plastic loudspeaker taken apart from an alarm, with 8 ohms coil capable of 20W
I built the following pre amplifier:
And also built the bridged TDA 2005 amplifier from the datasheet and connected both circuits, and used 9v as power supply.
It makes a strong hum noise which frequency varies in different med-high frequencies for no evident reason. However if I speak on the electret I can hear my voice, (although i'd expect a bigger amplification)
I took the speaker apart and used a multimeter in cc to analyze the output of both circuits. I got around -6v in the pre output and 3.75v in the amp output. (according to the multimeter).
This voltages change +- 0.5v when I speak close to the electret.
I would expect 0v when I don't speak to the mic, I'd like to understand why it has a continuous current component in the output.
Both circuits were assembled following the schemmatics.
I'd like to make this design work fine, without the noise component, and removing the continuous current from the output, which I suppose is not good for the speaker.
I hope you guys can shed some light to this.
Thanks,
Pendorcho.
Thanks,
Pendorcho.
