Don't even get me started...
So, what are threads for?
^what he saidSo, what are threads for?
Since it was only half power, I used it to warm cinnamon slice for coffee while I waited.What do you do with the toasts?
Obviously your mother didn't know that -30 degrees can't come between a man and his car.My Mother often reminded me several decades later the winter, I had the 1600cc engine out with parts in the basement since it was -30'C in the garage.
I had one of those in Colorado where we had snow. That car would not spin around in the snow. It would go 1/2 way and proceed backwards no mater what you did with the gas or steering.Blunders from the drawing board you say...
Had a 1979 Chevy Monza 2+2 hatchback, 305 cu. in. engine. It was a V8.
Anyways it used to cost an extra $85 to change the drivers side firewall spark plug during tune ups.
The reason why was although the car was an engineering masterpiece on the drawing board. In practical terms for the mechanic it was a nightmare.
The last spark plug on the drivers side by the drivers compartment was too tight get your hand in and fit a wrench socket on the spark plug. Never mind taking off and putting on the rubber boot for the spark plug.
The tuneup were $85 higher than other 305 based engines. The $85 fix was to undo the left motor mount. While the car was on a hoist. Then place a large 4" x 4" x 4 foot post under the oil pan and gently let the car down on the hoist till it twisted the motor to allow the mechanic to get his had down from the top while standing on a step ladder. Then bolt it all back up and proceed with the tune-up. About 1 year later MAC tools or Snap-On came out with a flexible goose neck attachment to fit the socket on the ratchet wrench. It was able to fit in the gap the hand could not and remove and replace the spark plug. However the cost of tuning the Monza never came down.
Nice car otherwise.
To this day I tell people that Haynes' 'Engine Rebuild" instructions were:In UK we had those HYNES MANUALS they were popular so I got one. For every job it tells you to disconnect the battery and remove the driver seat. I threw away that useless book.
1. Remove hood.
2. Remove engine.
3. Installation is reverse of above.
Only if comes from a Mgr whose career followed the Peter Principle.Almost as good as the advice you get on ETO.![]()
In case of dead battery, no charger and urgent need.
Required:
- awareness of AC power risks and safe use
- 15A or more power diode, hookup wire
- one toaster (1800W)
- Connect neutral to chassis (-)
& hot thru toaster and diode to (+)
wait 5~10 min. start car.
Techie details.
High Voltage & Nichrome heater wire resistance acts as current source but with 1 diode only half power.
At no time was car at risk of high AC voltage since toaster drops it down to Vbat.
In the end, all my cars, since 1971, have been used, cheap and at the least run and will move/stop. I rarely wash them (the dirt protects the wax) and many features don't work, in which case I then decide I don't need that/those feature(s) (ABS? Who CARES... - One fan speed?. Beats none!).
Have saved a boat load of money over the years and not one (ever) has one of them been broken into (too scary, I assume).
1. Remove hood.
2. Remove engine.
The other advantage with an old car is that you can park it anywhere with little fear of it being broken into. Another friend has an Audi, but most of the time he drives a Renault because he is afraid the Audi will be vandalised/broken into.
it doesn't have A/C but it'll push lot heat inside
well, currently not, outside is over -23c'Do you ever need A/C in Finland?![]()
well, currently not, outside is over -23c'But it helps to take moisture off the car (I keep my own cars doors open to let moisture out after ride, keeps doors un-frozen better)
In summer A/C is also nice, summer can be quite hot in here too ;D
