I'm still experimenting with IR remotes controls, and programming PIC's to use with them - so as NEC remotes (often listed as 'Arduino' remotes) are dirt cheap (only 22 pence from China), I ordered a few different ones - to go along with the couple of similar ones I already have.
I was shocked to find that the key assignments have no bearing on the labels, and are simply the physical position on the remotes - so the remotes are identical other than the labels on the front. For example, '1' on the black remote is the same code as 'CH-' on the silver remote, '#' is '200+' etc, and '1', '3', '7' and '9' on the silver remote don't even exist on the black remote, as they are the missing corners of the cursor section.
The address code of the remotes is identical as well, and is simply 0x00 - it makes the remotes less useful as replacements, as you've got to ensure you find one with the labels in the right places![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
On a further shock, the new gaming PC I bought earlier this year has a silly 'flashing light display' inside, and comes with a similar looking remote to alter it, or turn it off (this gets done the instant it's turned ON) - however, while the remote looks identical, it produces no output from a normal TSOP IR receiver, so I've no idea what system it uses. I'll have to get hold of a photo-transistor to see what it's putting out.
