Thuria said:I want to use 24 volts signal to input signal of PIC 16F84A. How can I convert?
eblc1388 said:Let's say we limit the input current to 1mA which is quite reasonable when the datasheet says input max clamp current is +/-20mA.
With 10 inputs at 24 volt, the current through the input protection diodes is sufficient to power my PIC as it takes only a few mA normally.
The 5V regulator shuts down, Vdd shoots up, PIC killed. You come back to this forum asking why?
Use at least a voltage divider or a very large value resistor.
Is it a square wave? what are you trying to do?Thuria said:I want to use 24 volts signal to input signal of PIC 16F84A. How can I convert?
