Look at Section 13 in the datasheet, starting on Page 89. There's even sample assembly code there. Everything you need. That's the way I learned to do it.Could someone write code sample to help me understand how to read/write eeprom so when I power off circuit.
Program will remember what speed routine was running and when I turn power back on it will return back to that speed routine.
tempswitch EQU H'22' ; temporary switch setting
MENU
BTFSC PORTA,SW1
GOTO SPEED1
BTFSC PORTA,SW2
GOTO SPEED2
BTFSC PORTA,SW3
GOTO SPEED3
BTFSC PORTA,SW4
GOTO SPEED4
BTFSC tempswitch,SW1
GOTO SPEED1
BTFSC tempswitch,SW2
GOTO SPEED2
BTFSC tempswitch,SW3
GOTO SPEED3
BTFSC tempswitch,SW4
GOTO SPEED4
GOTO MENU
;===============RESET : MAIN BOOT ROUTINE=======================
RESET
MOVLW B'00000111' ;Disable Comparator module's
MOVWF CMCON
BSF STATUS,RP0 ;Switch to register bank 1
;Disable pull-ups
;INT on rising edge
;TMR0 to CLKOUT
;TMR0 Incr low2high trans.
;Prescaler assign to Timer0
;Prescaler rate is 1:256
MOVLW B'11010111' ;Set PIC options (See datasheet).
MOVWF OPTION_REG ;Write the OPTION register.
CLRF INTCON ;Disable interrupts
MOVLW B'00000000' ; ALL RB PORTS OUTPUTS
MOVWF 0X86
MOVLW B'00110011' ;RA 0,1,4,5 ports are inputs
MOVWF 0X85 ;RA 2,3,6,7 PORTS OUTPUTS
BCF STATUS,RP0 ;Switch Back to reg. Bank 0
CLRF PORTB
goto MENU
;========================= MAIN PROGRAM =========================
;=======================SPEED ROUTINES===========================
SPEED1
CLR tempswitch
BSF tempswitch, SW1
E1
MOVLW B'00000100' ;LED ON TO SHOW SPEED1 SELECTED
MOVWF PORTA
MOVLW B'00000001' ;LED1
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B'00000010' ;LED2
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B'00000100' ;LED3
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B'00001000' ;LED4
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B'00010000' ;LED5
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B'00100000' ;LED6
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B'01000000' ;LED7
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B'10000000' ;LED8
MOVWF PORTB
CALL DELAY_ROUTINE
MOVWF PORTB
CALL DELAY_ROUTINE
MOVWF PORTB
CALL DELAY_ROUTINE
MOVWF PORTB
CALL DELAY_ROUTINE
MOVWF PORTB
CALL DELAY_ROUTINE
MOVWF PORTB
CALL DELAY_ROUTINE
MOVWF PORTB
CALL DELAY_ROUTINE
goto MENU
SPEED2
CLR tempswitch
BSF tempswitch, SW2
MOVLW B'00001000' ;LED ON TO SHOW SPEED2 SELECTED
MOVWF PORTA
MOVWF PORTB
CALL DELAY_ROUTINE1
MOVWF PORTB
CALL DELAY_ROUTINE1
MOVWF PORTB
CALL DELAY_ROUTINE1
MOVWF PORTB
CALL DELAY_ROUTINE1
MOVWF PORTB
CALL DELAY_ROUTINE1
MOVWF PORTB
CALL DELAY_ROUTINE1
MOVWF PORTB
CALL DELAY_ROUTINE1
MOVWF PORTB
CALL DELAY_ROUTINE1
MOVWF PORTB
CALL DELAY_ROUTINE1
MOVWF PORTB
CALL DELAY_ROUTINE1
MOVWF PORTB
CALL DELAY_ROUTINE1
MOVWF PORTB
CALL DELAY_ROUTINE1
MOVWF PORTB
CALL DELAY_ROUTINE1
MOVWF PORTB
CALL DELAY_ROUTINE1
goto MENu
SPEED3
CLR tempswitch
BSF tempswitch, SW3
E3
MOVLW B'01000000' ;LED ON TO SHOW SPEED3 SELECTED
MOVWF PORTA
MOVWF PORTB
CALL DELAY_ROUTINE2
MOVWF PORTB
CALL DELAY_ROUTINE2
MOVWF PORTB
CALL DELAY_ROUTINE2
MOVWF PORTB
CALL DELAY_ROUTINE2
MOVWF PORTB
CALL DELAY_ROUTINE2
MOVWF PORTB
CALL DELAY_ROUTINE2
MOVWF PORTB
CALL DELAY_ROUTINE2
MOVWF PORTB
CALL DELAY_ROUTINE2
MOVWF PORTB
CALL DELAY_ROUTINE2
MOVWF PORTB
CALL DELAY_ROUTINE2
MOVWF PORTB
CALL DELAY_ROUTINE2
MOVWF PORTB
CALL DELAY_ROUTINE2
MOVWF PORTB
CALL DELAY_ROUTINE2
MOVWF PORTB
CALL DELAY_ROUTINE2
goto MENU
SPEED4
CLR tempswitch
BSF tempswitch, SW4
E4
MOVLW B'10000000' ;LED ON TO SHOW SPEED SELECTED
MOVWF PORTA
MOVLW B'00000011' ;LED1,2
MOVWF PORTB
CALL DELAY_ROUTINE3
MOVLW B'00001100' ;LED3,4
MOVWF PORTB
CALL DELAY_ROUTINE3
MOVLW B'00110000' ;LED5,6
MOVWF PORTB
CALL DELAY_ROUTINE3
MOVLW B'11000000' ;LED7,8
MOVWF PORTB
CALL DELAY_ROUTINE3
MOVWF PORTB
CALL DELAY_ROUTINE3
MOVWF PORTB
CALL DELAY_ROUTINE3
GOTO MENU
