nightcatz said:hi guys ,
I have got a 8 inch sub-woofer ...now I want to buiild an amplifier for the sub-woofer but I dont know the ratings of the speaker ....Is there any way to measure the wattage of the sub...
nightcatz said:you did not answer my question what should be the wattage of the amp that can drive the 8 inch woofer
nightcatz said:audio guru u have suggested me to build a fairly large sealed enclosure .....will a 11"x11"x11" cube be fairly large for the 8inch sub...
The enclosure is so small for an 8 inch woofer that it will boom at about 150Hz and will not have any deep bass.nightcatz said:audio guru u have suggested me to build a fairly large sealed enclosure .....will a 11"x11"x11" cube be fairly large for the 8inch sub?
A sealed enclosure goes pretty low if it is large and the woofer is good quality.will the sealed enclosure produce bass reflex like the vented one?
The schematic in the datasheet shows polarities. The open bar on the capacitor symbol is the positive wire.please tell me the polarities of the capacitors c2-c6 in the split supply version
