ZGrizzlyWord
Everything powered up when I plugged it in, but the SCR never fired. Should the diode allow or disallow current through the SCR? (the diode above the SCR)
Thanks.
Thanks.
D2 (1N4006) should be polarised as shown in my previous post, to block current from R1 to the SCR. Its purpose is to 'short out' the damaging back-EMF generated when the coil current is switched off.Should the diode allow or disallow current through the SCR? (the diode above the SCR)
You hopefully have the diac in series between the top of C2 and the SCR gate? Try increasing the value of C2 to, say, 47u (it may not hold enough charge to fire the SCR). Do you have the triggering spec from the datasheet?
