Hey all...
I was just curious but would a 25 Volt Ac Motor be able to pull 50lbs...let so say on wheels? I dont have the exact motor specs but would this be achievable with a certain gear ratio or a certain circuit that could amplify the power going to the motor to lets say 30-40 volts? The actual base of the motor (not including the shaft) is about 3 cm long, 2 cm wide and 2 cm high? If so what sort of speed could be achievable...? Thank you for your imput.
The motor does work on both Ac and Dc...from an adapter...
So how many volts would i need in ac (from battery's) and then convert to dc to drive the motor faster.?
