Yes that looks like a professional solution.
Note the 1000ma version needs a minimum of 6v supply, so you'd be better powering this from a 7.2v battery pack, the good thing about using a switching reg like this is that its much more effecient, ie your batteries will last longer than if you used just a simple resistor, and the brightness of the led will be constant.
You could put a 1k ohm pot acrross 0v and 7.2v supply, and connect the wiper to the analogue dimming i/p on the board, then you would have a brightness control.
To be honest I'd forget the icop board, it looks like an old inefficient design, and those electrolytics have probably gone high impedance.
I'm near certain that your device was nothing like the image you posted, I think it was nothing more than a glorified torch/detector probably only capable of detecting movement.
